Results 1 to 3 of 3
Thread: What diameter fuel line required for twin carb 4AG conversion?
    Default What diameter fuel line required for twin carb 4AG conversion?
    Thought I'd give the forum a shot on this one. (for old times sake)
    I'd like to know from someone that has a 4AG twin carb (webers or dellortos) powered car as to what fuel line diameter size you are using from the tank to the carbs themselves.
    I remember reading years ago that they should have 8mm (5/16") line. That was what I saw recommended.
    The car is a KE70 Corolla. The steel lines and flex hose in the car are 6mm (1/4") feed size and I believe 4mm return size. This is what powered the old 4KC from factory.
    FWIW the engine is fairly mild. It is a rebuilt 16V with 264 cams, valve springs, headers, etc. (Shouldn't need a crazy amount of fuel supply.)
    Anyone run their 4ag carb car with 6mm IN and 4mm OUT? Did it cause problems? Did you run new lines and increase to 8mm IN?
    Thanks to anyone that might read this!
    Jun 2018
    New South Wales
    Default Re: What diameter fuel line required for twin carb 4AG conversion?
    Generally speaking most side draught carbies for use with inline engines use 5/16”, this will of course depend on the carbies you are using? Have you made this decision yet?
    Sent from my iPhone using Tapatalk
    Quote Originally Posted by Southern988 View Post
    Yep, the carbies have 5/16" pipe coming off them at the union . I have 40mm dellortos from an Alfa engine.
    Obviously I will run 5/16" (8mm) to connect them, but I am trying to decide whether I feed them with the 6mm steel lines that come from the tank to the engine bay. then step the hose up from 6mm to 8mm just before the carbs.
  1. Carb to EFI fuel tank conversion. RA23
    By masterofsinanju in forum Tech and Conversions
    Last Post: 02-09-2016, 05:44 PM
  2. 2T Twin Carb Install
    By RACINROLLA in forum Tech and Conversions
    Last Post: 30-09-2015, 05:40 PM
  3. A70 fuel line diameter
    By big JON in forum Tech and Conversions
    Last Post: 25-04-2009, 05:12 PM
  4. Twin Carb fuel setup
    By soulfire in forum Tech and Conversions
    Last Post: 18-12-2008, 02:38 PM
  5. fuel line carb to efi
    By 3sfe in forum Tech and Conversions
    Last Post: 27-03-2007, 01:02 PM
