Results 1 to 3 of 3
Thread: WTB - RA60 stock rear sway bar ~15mm
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    Default WTB - RA60 stock rear sway bar ~15mm
    Wanted to buy.
    RA60 Celica rear sway bar, (or similar, eg. Corona wagon RT142, KE70, any RWD Toyota) stock rear sway bar ~15mm. After a standard size for specific project which I believe is 15mm or 16mm. Will pay shipping or swap other parts. Thanks.
    Jan 2017
    Default Re: WTB - RA60 stock rear sway bar ~15mm
    They are mounted differently on the chassis as I remember, the KE70 has horizontal holes and bolts in the bar, the Celica has vertical pins like the front sways. The RA60 is 30% larger in diameter and the same stiffer. This is a KE70 holding the bucket in the photo.
    https://www.rollaclub.com/board/topi...he-girls-ke70/
    If you're really desperate in a month I might be able to help, but I'm sure other guys can do it easier and cheaper. Have you put the ad up on Rollaclub?
    Tasmania
    Quote Originally Posted by hoonicorn View Post
    Thanks for the reply. Holding the weighted bucket is brilliant engineering. You probably have many more tricks I'm sure.
    I'm fairly well researched, but if you measure the diameter of your bars and have a RA60 or similar to KE70 in the right size, I want it. My research says I want the RA60 rear bar. Thanks.
  1. Replies: 0
    Last Post: 08-07-2017, 09:12 AM
  2. rear sway bar for a rt104 corona
    By mattyvee1 in forum Tech and Conversions
    Last Post: 22-07-2011, 04:23 PM
  3. Rear Sway Bar types, which is better?
    By ballpencil in forum Tech and Conversions
    Last Post: 22-03-2011, 09:17 AM
  4. ke35 rear sway bar
    By concord.dawn in forum Tech and Conversions
    Last Post: 24-06-2009, 12:11 PM
  5. RA28 Rear sway bar??
    By Gleno28 in forum Tech and Conversions
    Last Post: 06-02-2006, 12:39 PM
