Results 1 to 2 of 2
Thread: jzx91 2JZ-GE - Toyota 89661-22680 ECU help
    Apr 2019
    Default jzx91 2JZ-GE - Toyota 89661-22680 ECU help
    Hi all,
    Planning a 2JZ NA-t build and trying to organise the ECU side of things first.
    Multiple places state that ALL 2JZ GE and GTE use the same pinouts - unfortunately it's not the case when it comes to the JZX91 - it uses the same plug as the JZX90 1JZ-GTE and I believe the JZZ30
    The dilemma hear is that the GE motor uses a distributor not coils - (I believe the Auto wiring wouldn't come into play as jzx90 with the 1JZ-GTE also have an Auto option)
    Does anyone know if the pinouts for the essentials are the same, or does anyone have a pinout for the jzx91 2JZ-GE?
    Many thanks
    Default Re: jzx91 2JZ-GE - Toyota 89661-22680 ECU help
    What would be you plan with having the same pinouts - is the common theme to use a 2JZ-GTE ECU on the NA-T conversion?
    Having a distributor shouldn't be a problem for making a NA-T as it has been done in the past, although if you plan on using a 2JZ-GTE ECU then you will need to convert to COP or do you plan on using a JZX90 1JZ-GTE ECU?
  1. 1JZ VVTi into JZX91 - few questions
    By cresslux in forum Tech and Conversions
    Last Post: 21-11-2014, 10:52 AM
  2. A/C not working in my JZX90 or JZX91
    By SirLagz in forum Tech and Conversions
    Last Post: 06-01-2013, 12:42 AM
  3. Replace ECU 89661-12770 with 89661-12420 ?
    By munkey in forum Tech and Conversions
    Last Post: 22-04-2010, 09:06 PM
  4. ecu pinouts for bigport 4age Toyota Part Number: 89661-12250
    By ian6375 in forum Tech and Conversions
    Last Post: 20-04-2009, 07:23 PM
