Results 1 to 5 of 5
Thread: Need help with wiring in an OBD plug for the 1JZ/2JZ VVTI JZX110/JZS171/JZS161
    Jun 2019
    Question Need help with wiring in an OBD plug for the 1JZ/2JZ VVTI JZX110/JZS171/JZS161
    Does anyone know how to wire an OBD plug with the 1jz VVTI jzx110/jzs171 ECU? Same as the Aristo 2JZ VVTI.
    I've done a conversion into another car using the stock jzs171 ecu, I can see the SIL pin on wilbos 2JZ VVTI wiring page is used to output OBDII information from the ECU but I'm not sure how I would wire in a connector.
    I've found this link: [http://www.2jzgarage.com/2013/01/2jz...Kc1KQZVIfc_pk) which tells me how I can view the OBD information on my phone using a bluetooth scanner but I need a pinout or something to wire in the plug if anyone can help.
    May 2010
    Moscow
    Default Re: Need help with wiring in an OBD plug for the 1JZ/2JZ VVTI JZX110/JZS171/JZS161
    see my recent article on the topic
    https://www.lextreme.com/scan-tools-...-engine-swaps/
    Jun 2019
    Awesome, thanks for that. Just a couple of questions: on the diagram it runs 12v off the battery, this won't drain it will it? And I'm guessing TC pin goes to #5 signal ground?
    Jun 2019
    Looks like TC just goes to pin 13, so I guess pin 5 is just another chassis ground?
    TC goes to pin 13 SIL goes to pin 7 Earth is pin4 12v to pin16. I use a Launch Creader VI+ to read codes and an ELM327 [I use HH OBD ADVANCED unit ]with my smartphone running inCarDoc Pro to see live feed. Pay the few dollars for the Pro version.
    Jealousy is a curse
  1. Replies: 11
    Last Post: 11-09-2018, 04:39 PM
  2. 1JZ-GTE [JZX110/JZS171] MAF issue
    By George in forum Tech and Conversions
    Last Post: 08-07-2016, 08:33 AM
  3. jzs171 1j vvti ecu pinout
    By kiwi84 in forum Tech and Conversions
    Last Post: 07-07-2016, 11:38 AM
  4. 2jz-gte vvti jzs161 Mx83 cressida wiring help needed
    By 2JZmx83GTE in forum Tech and Conversions
    Last Post: 28-08-2013, 10:53 PM
  5. 1jz vvti jzx110 with a 2jz vvti ecu will this work
    By Tonys87monte in forum Tech and Conversions
    Last Post: 16-08-2012, 05:36 AM
