Results 1 to 6 of 6
Thread: Bendix Releases Aerosol Range
    Forum Sponsor Grease Monkey
    Jul 2016
    Default Bendix Releases Aerosol Range
    Bendix have got it in the can with our new range of super convenient spray cans. The all new range of Bendix spray cans, available at your nearest automotive stockist now.
    Cleanup – Brake & Parts Cleaner
    A dynamic cleaner designed to rapidly remove brake fluids, oils, dust, dirt, grease and other contaminants from brake linings, disc pads, drums, clutch plates, rotors, cylinders and springs. Stops squeal in disc brakes and can be applied without disassembly of brakes. Bendix Cleanup dries super-fast which enables quicker brake part changes. It also cleans other workshop equipment.
    1. Effectively removes impurities from brake components
    2. Leaves no residue, staining and is non-corrosive
    3. Cleans disc rotors after machining, before brake pad installation
    4. Cleans instantly to stop squeaks and squeals in brakes
    5. Use on brake parts and other degreasing applications
    Jul 2016
    Default Re: Bendix Releases Aerosol Range
    Shine – Shines Tyres
    The easiest and most effective way to shine your tyres, mudflaps and bumpers, is Bendix Shine, designed to give the ultimate new appearance. Prevents dirt from forming on tyres. Just spray on and let the product produce the shine on your tyres. Ideal for use on low profile and performance tyres.
    1. Easy and effective way to shine your tyres, mudflaps & bumper bars.
    2. Prevents dirt and road grime forming on tyres.
    3. Long lasting.
    4. Ideal to use on low profile and performance tyres.
    Jul 2016
    Degrease – Removes Oil & Grease
    A powerful multipurpose degreaser designed to remove grease and grime from numerous surfaces including engines, lawn mowers, outboard motors, concrete floors, driveways and general workshop surfaces. Bendix Degrease is formulated to quickly soften and remove grease and grime in one application leaving the surface sparkling clean.
    1. Degreases engine and motor parts.
    2. Removes oil and other deposits from concrete paths and other masonry surfaces.
    3. Suitable for agricultural uses – tractors, trailers, chain saws and tools.
    4. Also suitable for industrial uses – stationary machinery, forklifts and cranes.
    Jul 2016
    Multi-Use – Penetrates & Lubricates
    A heavy duty water dispersant designed to displace moisture and assist in lubricating, protecting and starting wet motors. The product is suitable to be used on most machinery parts, heavy duty engines and hobby engines. It is fast acting in displacing moisture from engines and motor parts and protects against corrosion. Bendix Multi-Use also stops squeaks and loosens rusted parts.
    1. Penetrant – loosens rusted nuts and metal parts.
    2. Lubricant – Eliminates squeaks, loosens hinges and rusted parts.
    3. Lubricates and protects moving parts.
    4. For domestic uses such as lawnmowers, generators and other garden machinery
    Jul 2016
    Smooth – White Lithium Grease
    An all-purpose lubricant designed to lubricate and protect surfaces from abrading or scratching one another and helps prevent squeaking. It is an ideal lubricant for wheel bearings operating under all service conditions, CV joints, chassis lubrication, metal hinges, door catches, striker plates, cables and springs, outboard motor s, chains, winches, jacks, garden tools etc. It is suitable for automotive (cars, trucks, tractors and trailers), marine, agriculture, general industrial and household use.
    1. Lubricates chains for motorcycles, chainsaws, cranes, conveyors, etc.
    2. Powerful lubricant for all industrial and domestic purposes.
    3. Lubricates, protects and prevents abrasions, scratches, squeaks & squeals.
    4. Ideal for bearings, rollers, hinges, linkages and springs.
    5. Corrosion inhibitor ideal for outboard motors.
    Jul 2016
    Silicone – Lubricates & Protects
    A heavy duty lubricant designed to lubricate, waterproof and protect most surfaces from binding, corroding and squeaking. Bendix Silicone is an ideal protectant for plastic, vinyl leather and rubber, window and sliding door tracks, doors hinges, rubber gaskets, metals, vinyl, fibreglass, locks, fishing equipment and boat fittings. It is suitable for marine, automotive and household applications.
    1. Industrial strength using a refined grade of Silicone.
    2. Designed to lubricate, waterproof and protect surfaces from binding, corroding and squeaking.
    3. Suitable for automotive, marine and household use.
    4. Ideal lubricant for chains and moving belts, for sliding door tracks & hinges.
    For more information https://www.bendix.com.au/product-ra...sumables-range
  1. Replies: 0
    Last Post: 24-10-2019, 06:58 PM
  2. Replies: 0
    Last Post: 28-03-2019, 10:01 PM
  3. Introduction to Bendix Brake Pad Range
    By BENDIX in forum BENDIX
    Last Post: 24-02-2017, 12:13 PM
  4. W56 box and Low Range 2WD
    By TooF in forum Tech and Conversions
    Last Post: 08-05-2008, 02:33 PM
  5. The hilux range??
    By mgfe in forum Tech and Conversions
    Last Post: 10-05-2007, 07:40 AM
