Results 1 to 4 of 4
Thread: Electric Powersteering - RN40 Hilux
    New Zealand
    Default Electric Powersteering - RN40 Hilux
    Have dug through the forum but not found anything Hilux related.
    Doing a 2JZ conversion on my RN40 Hilux. Have swapped in the complete LN85 front suspension including the thicker torsion bars from the diesel. I was planning to use the LN85 powesteering box but the bolt pattern is different to the 40 series Hilux and looking at other options to cutting up the chassis to make it fit. So electric powersteering seems like a potential option but basically have a single piece shaft from steering wheel to steering box and can't legally cut and weld in NZ. potentially can be cut , resplined or sleeved as an option. Or can use a shaft from a different Toyota to mate the power column to the factory steering box. The other complication is I need to retain the column shift mechanism . Anyone done a similar swap and have pics or suggestions on a suitable column and controller?
    Non power steer is not an option with a small steering wheel to fit my knees and -27 offset 15x8 wheels to fill out the 4WD guards.
    Callum
    Nothing but a Backyard Mechanic caam's Avatar
    Apr 2010
    Default Re: Electric Powersteering - RN40 Hilux
    Not Hilux related but I found a Yaris column to be the smallest and easiest to work with, played with a few types before settling on the yaris unit.
    It is splined both ends if you have the tooling to respline your original once cut.
    This thread was instrumental
    http://www.hachiroku.net/forums/foru...teering-thread
    I had an RN46 on 285/75s with a 330mm wheel, it wasn't as bad as you'd expect. But I do get the appeal of power steering.
    Cheers, Cameron
    SR20DET TA23
    Jul 2012
    Was talking to a bloke who races a mitsubishi Lancer in classic rally, an old 1970s one. It had electric power steering from a suzuki Baleno I think. He said all the rally guys do that if they are serious about it.
    New Zealand
    Thanks for the input guys. Have acquired a Prius column so will see where that takes me.
    Having driven the Hilux for the last 18 months powersteering is not negotiable anymore.
  1. WTB: RN40 79-83 hilux 4x2 Brisbane
    By ratta tat tat in forum Cars and Parts Wanted
    Last Post: 22-12-2018, 02:07 PM
  2. Hilux RN40 (?) Rear Diff Oil Capacity
    By Mk1_Oz in forum Tech and Conversions
    Last Post: 30-08-2013, 11:28 AM
  3. RN40 hilux diff question
    By soulfire in forum Tech and Conversions
    Last Post: 09-04-2008, 12:05 PM
  4. rn40 hilux engine and gearbox questions
    By vanman in forum Tech and Conversions
    Last Post: 09-04-2006, 06:07 PM
