The TPS is now connected to your standalone ECU, so Toyota will not be able to help. You will need to refer to the ECU installation instructions for how to calibrate the TPS. Typically the procedure will be like this...
Cheers... jondee86LINK G4 PlugIn Installation Manual
1. Connect a laptop/notebook PC to the ECU and connect to the ECU using PCLink.
2. Under the Analog Channels menu, ensure that the correct An Volt channel is set to 'TPS (Main)'. Refer to
the pin functions section of this manual for details.
3. Under the 'Options' menu, select 'TPS calibration'.
4. Follow the on screen instructions.
5. Select the 'Analog Inputs' tab in the runtime values section of PCLink (lower part of the screen).
6. Ensure the Throttle Position value reads 0% when the throttle is closed and 100% when fully open.
7. Perform a 'Store' by pressing F4
