Results 1 to 3 of 3
Thread: 2ZZ Engine Conversion into a ZZE-122
    Aug 2018
    Default 2ZZ Engine Conversion into a ZZE-122
    I will have access to a 2ZZ Sportivo Engine conversion from a written off car that I want to fit into a ZZE-122 sedan we currently race , all I need to know can anyone tell me exactly what is required
    My car is Japanese build car so does the donor car have to be a jap built car to
    I believe the 5 speed gearbox bolts straight up and as we only really use 1st 2nd 3rd and 4th gear when racing do I really need a 6 speed box
    Default Re: 2ZZ Engine Conversion into a ZZE-122
    Quote Originally Posted by Tonic View Post
    Even though you're only using 1-4 I'd still go with the 6-speed box, it's a short-ratio box and you want to keep the 2ZZ in lift as much as possible (which the 6-speed just barely does for the 1st/2nd shift, a 5-speed would be even worse).
    Aug 2018
    Quote Originally Posted by Hiro View Post
    Ok thanks for the heads up, I should have said we use 2nd and 3rd gear at Marulan, not quite hitting the 6,400 rev limiter in third and could possibly use 4th but no real advantage
    First is only used when taking off , from then on its 2nd and 3rd
    We be running at the next cheap car challenge at Marulan on the 28th and there should be a Sportivo running as well so we can see how they find things
  1. Engine conversion legalities
    By Teknics in forum Tech and Conversions
    Last Post: 09-01-2010, 09:17 PM
  2. X71 engine conversion
    Last Post: 20-09-2007, 04:45 PM
  3. best engine for conversion
    By brend0n in forum Tech and Conversions
    Last Post: 13-07-2007, 10:42 PM
  4. ra40 engine conversion?
    By noobra in forum Tech and Conversions
    Last Post: 26-11-2006, 01:16 PM
