Results 1 to 6 of 6
Thread: 1mz-fe rwd conversion in SA63
    Feb 2018
    Default 1mz-fe rwd conversion in SA63
    Hi peeps,
    I thought I'd post my project for some constructive criticism. Here's the early stages.
    1 sa63 liftback, 1 xv20 v6 Camry(engine,loom),wolf street ecu and hand controller, wideband O2, 1 rt142 avanté (f series disc rear subframe, fuel tank), r33 skyline f&r brakes rotors and master cylinder, S13 knuckles, camber tops and coilovers, gk tech 5 stud front hubs, GH sigma lca's, ms123 rear hubs.
    Any input on suitable rack ends for power steering. A bit puzzled by all the info I've searched on here.
    Hope that ajps height adjustable rear spring seats can be adapted and i will fit some camber and toe adjusters.
    Sigma lca's have ball joints with a press fit that is 0.4mm smaller than the s13 ones....maybe heat on the lca and freeze the ball joint may work????
    I will fab. An intake, rebuild the engine with forged rods and pistons. Also i will try to wedge a pair of Garrett gt2860r turbos on custom exhaust manifolds or a decent size single. Maybe a gtx3582r if twins won't fit. Bigger injectors, pump & lines with a surge tank.
    I would appreciate any positive input for my project
    Thanks Toymods Crew.
    Mar 2012
    Default Re: 1mz-fe rwd conversion in SA63
    I put a non VVTi 1MZ into a SA63, easy as, tons of room.
    With my KE, I used S13 crossmember, KE70 control arms, AE86 PS knuckles, S13 rack with R34 rack ends, AE82 tie rods, RT142 corolla steering knuckle from rack to coloum
    Feb 2018
    Cheers for the input samkaos. I've read the thread on your build. Nice work!
    Did the 1mz fit with the 2s bellhousing or do I need to source a 3y one?
    Mar 2012
    I couldnt get the starter to fit with a S bell, didnt try a Y (but I can, I have one). I went for a 4Runner 3VZ or 5VZ bell
    I have photos somewhere of the 1MZ in a SA63 I will dig up.
    Feb 2018
    The photos are definitely of interest Sam.
    I read through the thread on Joels build on here, which says to use the y belhousing. I have found one this weekend so I'll fit it and see how it looks.
    always looking like a Grease Monkey fibrewizard's Avatar
    Quote Originally Posted by samkaos View Post
    i know i am digging up an older thread, but currently researching a conversion i am planning and interested in transmission choices for the 3vz bellhousing as i just bought one. was it an R150, w5* transmission used with the 3vz bell
    2012 GT86
    V6 powered 5th gen celica. Sadly moved on to build below
    91 st185 aus delivered, V6 turb project,
    2015 Kun26r hilux
  1. 3S into my SA63
    By Imatool in forum Tech and Conversions
    Last Post: 17-09-2009, 01:13 PM
  2. 1G-GTE to SA63 Celica Conversion
    By Hipsi in forum Engine & Driveline Conversions
    Last Post: 27-02-2009, 11:14 PM
