Results 1 to 15 of 18
Thread: 1JZ in MA61 NO COLD START?
    Jun 2006
    Default 1JZ in MA61 NO COLD START?
    I've just purchaced my second (in a long list of cars) MA61, its got a 1jzgte installed. My problem is that there seems to be no cold start at all. When i start in the morning i have to keep the revs up or immediately stalls out, when the car gets upto normal temp its fine.
    I've tried taking out the ecu fuse in the engine bay but it did nothing (big green fuse in the fuse box)
    Any help would be great
    Default Re: 1JZ in MA61 NO COLD START?
    When the car turns off does the ISCV close? You should be able to hear it move if you get someone else to turn the engine off, The ISCV is located at the rear of the inlet manifold on the engine side, it has a black metal cover and connects to the manifold with two nuts.
    The ISCV is a valve that the ECU uses to let more / less air past the throttle to control the engines idle RPM.
    When you turn the engine off the ECU should move the ISCV to the fully open position, it does this so that it knows where it is for next time! ISCV should be powered by a relay which is controlled via the ECU via the M-REL output. Having the ECU switch the M-REL allows the ISCV to keep power after the ignition has been removed (the ecu senses this and then moves the ISCV and then cuts power to the M-REL). Depending on how your car has been wired up this may not be the case?
    My suggestion would be to first remove the ISCV and check that it isn't gummed up and dirty (stopping it from moving). If it is dirty try and clean it with something like carby cleaner. If it looks fine then I would check that there is voltage at B1/B2 after ign has been switched off for a moment. If there isn't then you may have to search through the wiring and sort it out!.
    A guide to test the 7M-GTE (MA70) ISCV is here
    http://www.cygnusx1.net/supra/librar...fi/FI_106.html
    1JZ-GTE should be very similar!
    how much did it cost you, out of curiosity?
    After reading this thread I'm wondering if your Idle Air Control Valve is hooked up at all?
    Jun 2006
    Thats not the big disc looking thing at the turbo side of the engine, with 2 small pressure lines coming from it is it, its to the back of the engine?
    I know its not he factory bov as it looks completely differnet and isn't instaled anymore
    a picture is worth a thousand poorly described engine parts.
    I was thinking the same thing as norbs.. he's just quicker.. im traction impeded.
    I don’t think the ISCV needs to be “connected” to that pipe that goes from one side of the engine to the other near the turbos as it just opens and gets air anyway.
    Pics would definitely help though. Sorry, I haven’t had stock turbos or ISCV for long time so no piccies here
    QUICKEST 1JZ'S IN OZ
    i suspect if its not connected to the other side, it might be blocked so as not to vent boost or something?
    Quote Originally Posted by SL666
    There is a one way check valve inbetween the ISCV and where it bolts to the inlet so it wouldn't (shouldn't :S) be venting boost if it isn't connected round to the turbo side....and it should still work as chris said!
    Also if you're in Bris and want to bring it round so I can have a look you're welcome to
    since you're on the sunny coast you can bring it round and I can have a look
    You sold some CA18 ke70 mounts to my next door neighbour.
    Jun 2006
    That wasn't me i'm affraid, never sold engine mounts before
    Anyway here is the pic, to me now it does look like the factory BOV, especially to what its plumbed into, so i don't think thats the problem
    that is indeed the factory bov.
    Jun 2006
    So keep looking, cuz thats not the problem
    Also when i start it in the morning when its dead cold it has a little clakc then a second later it goes away. And when its at 2000rpm it clacks a little , Big end? stuffed h-lifter???
    The sound maybe the injectors.
    1JZ-GTE doesn't have hydrulic lifters so it can't be that.
    Do you want to tell folks where you are? I've offered to help as has Chris, perhaps if you let us know where you are someone near you can offer an hand?
  1. MA61 Part Numbers & General Infomation
    Last Post: 27-03-2013, 01:31 AM
  2. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
  3. Cold Start Injector Pipe
    Last Post: 04-03-2006, 11:02 PM
