Results 1 to 11 of 11
Thread: ignition fire polarity GZE
    S.A
    Default ignition fire polarity GZE
    can someone tell me how the waste spark is setup on a GZE
    IE
    CYL NO.1 + fire
    CYL NO.2 - fire
    CYL NO.3 + fire
    CYL NO.4 - fire
    or
    no.1 - fire
    no 2 - fire
    no 3 + fire
    no 4 + fire
    ETC ETC
    Reason i ask is that i checked timing for the first time in a while yesterday and found that my no.1 cylinder is a - fire ( timing light wont work unless the spark lead is hooked up with the spark traveling from the motor to the coil.)
    It has never been like this before as i have never had to hook the timing light up backwards. The only thing i can think of os that since installing the CDI ignition it has changed the polarity.
    As it is my polarity is the same as my second example
    AND YES I HAVE BEEN OVER ALL MY WIRING AND EVERYTHING IS WIRED CORRECT !!!
    S.A
    Default Re: ignition fire polarity GZE
    somebody must know this ???
    or beable to check it with a timing light for me !!
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Hi 30PSI,
    Yeah I have the same thing with my timing light (I run a wasted spark setup on my AW11). HT voltage polarity doesn't matter for the engine of course. BUT current direction matters to you timing lights pick up circuit. Its just the timing light...it must have been designed to work only one way around. If its a problem just swap 1 and 4 at the coil.
    Cheers, Nick
    == 4AGZE SC14 Supercharged ==
    S.A
    would ya know how the factory set theres up as far as polarity goes ??
    Quote Originally Posted by 30psi 4agte
    I'm just wondering if there's something with the timing light pickup that gets confused by CDI... As far as I understand the waveforms are completely different.
    Mos.
    S.A
    good point m8
    Junior Member Grease Monkey RPM016T's Avatar
    Not sure if Im understanding the question 100% but if im right, when piston no 1 is @ TDC it'll spark whilst at the same time it sparks in cylinder number 3 (whilst both valves are open) to burn unused gas etc. and similiarly for cylinders 2 & 4.
    Would be interested in knowing what it means to have the spark travelling the opposite way? I wouldnt't have thought this was possible the way the coils are designed??
    Hope this help
    Canterbury
    RPM016T, are you are confused? In wasted spark setups 'paired' cylinders share a double ended coil. The 'paired' cylinders are always 360 degrees seperated in the 4-stroke cycle. For every ignition event the coil fires for, a sparked is 'wasted' in jumping the other gap in the cylinder on its exhaust stroke. Since the pressure is low in the exh stroke cylinder, not much energy is used to break down this spark plug gap. So in 4cyls with 1342 firing order (nearly 100% of them) cylinder 1 &4 are paired and 2 &3 are paired.
    The method of getting the coil to generate a spark are different, but there is still a spark and a corresponding 'current' during the spark. CDI sparks are shorter duration than inductive though.
    Cheers, Nick
    Quote Originally Posted by nick.parker
    Cheers, Nick
    Hmmm, I understand what you mean in the first part because i've been thru all that when I was using the standard ZE coil packs and I wired them into the wolf 3D. i.e. one spark firing in two different cylinder sequentialy. It was more that I was confused about the + & - polarity that 30psi was refering too...?
    CDI will throw your timing light out something shocking.
    Mine worked fine with normal ignition till I went CDI, then the whole thing went out the window.
    Facebook | LinkedIn
    S.A
    come up with any wayd around this mate?
  1. HELP - how to wire up a fuel pump
    Last Post: 21-06-2007, 12:15 PM
  2. Wastespark ignition (7mgte)
    Last Post: 22-06-2006, 04:58 PM
  3. 4channel Direct fire ignitor solutions
    Last Post: 15-06-2006, 12:28 PM
  4. 4 ignition outputs from 3 inputs
    By d-shiznit in forum Tech and Conversions
    Last Post: 11-06-2006, 07:35 PM
  5. 4k electric ignition problems
    By dave_ke30 in forum Tech and Conversions
    Last Post: 29-12-2005, 11:57 AM
