Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Thread: Turbo 1MZ 1994 RAV4
    Jun 2019
    TX
    Default Re: Turbo 1MZ 1994 RAV4
    Quote Originally Posted by samkaos View Post
    I moved away for a while, RAV was sitting unreg on a farm.
    Got it back, cleaned it up, going for rego this week.
    Took out the Panther ECU, put in stock ECU and AEM F/IC6. Tried mafless tune, AEM is laggy!! Put in 2.2k resistors across reluctor sensors, didnt help. Ended up with AFM after intercooler, before throttle body!!
    Made a rough MAF correction map, as it was maxing out at 4500RPM. Added an injector correction map. Not perfect but drives ok. Stock ECU does sometimes drop the power right down on boost. Deal with that later
    U151F controller still works well. Intercooler is more of a heater, looking at changing it.
    Running BC rods and stock pistons, I ran 16psi the other day (on sand), was fun!! and it survived
    Really glad to see your back and the projecti s moving fwd. Mind if I send you a PM? Had some questions about my own project.
    What is your max MAF g/s? Have you considered moving the MAF sensor pre-turbo but doing a breakout IAT sensor in a 2nd MAF where you have it now? This way you shouldn't max out the MAF readings and you'll get correct IATs?
    Jun 2019
    TX
    Would love to know more about this... please respond to DMs.
  1. Replies: 11
    Last Post: 04-12-2012, 12:53 PM
  2. Rav4 needs a new donk
    By RA28tragic in forum Tech and Conversions
    Last Post: 08-07-2008, 02:16 PM
  3. 96 Rav4 02 Sensor
    By rob1981 in forum Tech and Conversions
    Last Post: 13-06-2007, 05:41 PM
