Hi Guys,
I've just picked up a 1976 MX13 Corona Mark 2 in great original condition with a blown head gasket. I was always planning to do a 2JZ-GE conversion but the blown head gasket has helped to reduce the price and also speedup the conversion. I owned another example of the same car back in the early nineties and did a conversion to manual with a 5 speed celica gearbox
Thanks to the forums I've got most of the build set out with the following -
2JZ-GE with auto trans (dodgey knee so a manual is out)
standard ECU and wiring harness
potential transmission tunnel mods
sump from a JZS131 or JZS133
custom engine and gearbox mounts
I found an old post from Andrew Bolt who did the same conversion that suggests the cross member needs to be modified
extractors to clear steering box and custom exhaust
in tank fuel pump from a BA falcon
retain standard steering box
retain factory power steering and air conditioning
The car will be engineered once complete so I've spoken to a local engineer in Victoria to try and get an idea what I'm getting into and the cost.
I was originally going to use a front cut but they are pretty hard to come across. I can get a 2JZ-GE with auto trans from a JZA80 Supra but I wanted to make sure I get all the extra bits to do the conversion.
I've put together the following list
2JZ-GE with accessories and ignitors
auto transmission
power steering reservoir
intake and airbox
tailshaft
transmission shifter
fuel regulator
trans cooling lines
engine mounts
trans mount
radiator hoses
accelerator cable
Is there anything else I would normally need from a half cut to convert a non-efi car ?
Back in the day (early 2000s ??) a forum member Gianttomato had a 2JZ-GE powered Corona. I seem to remember it being a Mark 2. He was based in Melbourne and raced it regularly/occasionally. I'm not sure if he's still active around the place but he may have posted details of the conversion.
