Results 1 to 9 of 9
Thread: Need Australian Advice
    Jan 2017
    California
    Default Need Australian Advice
    Hey guys, it looks like I'll be moving to Australia for school from the states sometime in the next 6 months, and I'll be trying to pick up a Mk 2 supra down there to be my final project car, and since they only have the 5me in them I was planning to swap in a 2jzgte. Now I know your laws on that are a bit different than the ones over here in car hating California, but even after reading up I'm still not 100% sure what I can and cant do mod wise. My end goal is a 400-500 bhp (300-375 KW @ wheels) build on E85, a mild full internal rebuild, maybe mild cams, and a twin scroll turbo with a haltech computer running it. Now I've rebuilt my 6m so i have the mechanical part on that end down, and ive got Cap'n 2jz's post to help with the install, but I know nothing about turbos or the computer systems, so if anyone can point me to any good info on that as well i'd really appreciate it. First and foremost though I want to make sure i'm actually legal before i build the thing and cant pass rego.
    Thanks guys,
    Curtis
    Act
    Default Re: Need Australian Advice
    what state are you moving too.. laws are different in each state
    Jan 2011
    Take a look at the NSW requirements (since it's the only one I'm familiar with). Most states will be broadly similar (there is a nationally based standard), but you still need to check. Talk to a licensed certifier before you start making changes.
    http://www.rms.nsw.gov.au/documents/...ifications.pdf
    In short, looks like you would be legally able to do this, but it all comes down to finding an engineer/licensed certifier who is willing to sign off.
    Oct 2015
    Would be legal in most states. Since you're in California you would be aware of most of the emissions (or smog as you guys call it) issues you need. Mostly it'll just be a cat convertor in the exhaust and comply with noise testing. If you use a standard ECU from a Mk4 Supra you wouldn't need to do an emissions test because the car has been complied and sold here on the market, however if you use an aftermarket computer that would require an emissions test. Depending on the state will depend on how easy/hard it is to get one of those done. In NSW you can get them done at a testing station for free, whereas Victoria it's a few grand which is just ludicrous.
    For turbo stuff it's really down to how much reading and research you do! I ended up getting a few books on turbochargers and tuning to help me select the right size turbo for one of my past builds (and I still went too big :S).
    RA23 Celica - 18RG, 40mm Webers, 92mm Arias pistons, 11.1:1 C/R, 15x7 SSRs.
    910 Bluebird - FJ20ET, IRS 4.4 LSD, 251kW on E85
    910 Bluebird - RB25 Track Hack
    Jan 2017
    California
    The school I'm going to is in Launceston, TAS, but after graduation I'd be free to chose basically any major port city, so there's a little flexibility there, I have no problem doing all the cat and tuning work to pass emmisions, but in california we have this C.A.R.B law, which essentially states that anything before the intake ports or from the exhaust ports to the cat has to have special certification from the state (2-3x cost) to be legally mounted, and for an older generation car, or a swap like this things like manifold, downpipe, and intake system would be impossible to find, is there anything like that out there, or is it essentially a "if its safe, and the computer says you don't pollute you're good" kind of system?
    Jan 2017
    California
    As for the turbo stuff, I was looking at twin scroll's and found this quick spool valve idea that forces all exhaust into one scroll for low rpm and opens up the other one at high rpm. it doesnt seem to do much for i4's but i6's seem to get something -- anyway that's for another thread
    Junior Member Backyard Mechanic egamirrorim's Avatar
    Tasmania is notorious for drop bears - budget for an anti drop bear rig for the roof and front of your Supra.
    Jan 2017
    California
    way ahead of you, they sell a kit in Wyoming for their carnivorous Jackalope problem, with a little beef up should work great for drop bears too
    lol I haven't heard Jackalope in years!
    Good luck with the build, it will be a sweet combo.
