Results 1 to 5 of 5
Thread: T50 5 speed rebuild kit inc output shaft bushing
    Oct 2014
    Default T50 5 speed rebuild kit inc output shaft bushing
    any help appreciated
    Aug 2009
    Default Re: T50 5 speed rebuild kit inc output shaft bushing
    Quote Originally Posted by beard View Post
    What model car is it out of. Different models and year of manufacture use different input shaft bearings and od of output shaft. Rear output shaft bush you can buy from amayama.com, once you know part number. I have one bush in my shed, which I will be using, so will look at part number later for you.
    You can usually buy bearing, seal and gasket kits from places such as Burson Auto Parts. But the output bush is not included.
    Aug 2009
    Here is a eBay listing, in US, for full rebuild kit. As can be seen includes seals, bearings, synchro rings and gaskets. You can expect to pay between $350 and $400 Aus for full kit if you can still get them here.
    http://www.ebay.com.au/itm/BK176WS-B...cAAOSwLF1X2vTT
    I just checked output shaft bush and genuine part number is 90999-72022. At the moment Amayama has them listed for $17.98 Aus plus post.
    The later model gearbox 1983 to 1985 needs this front bearing, they are 68mm OD and a roller bearing as the earlier one is 62mm OD and a ball race. http://www.ebay.com.au/itm/T50-Input...YAAOSwnHZYdDSx Other than that they are the same throughout.
    Oct 2014
    Thanks for the links and advice, it's a 73 ta22. What's the ID of the bush u have if its still easy to measure.
    Aug 2009
    The bush is stored away at the moment. I know the ID is the same for all T50 and T40 boxes. The OD of slip yoke is the same for all T50 and t40.
  1. aristo a340e into jza80 supra - output shaft differences
    By midnight_purple_GA70 in forum Tech and Conversions
    Last Post: 13-04-2011, 10:56 AM
  2. T-50 Gearbox output shaft damage after crash
    By Javal in forum Tech and Conversions
    Last Post: 26-04-2010, 11:08 PM
  3. Toyota L40 gearbox output shaft/tailshaft spline
    Last Post: 30-08-2006, 11:03 AM
