Results 1 to 4 of 4
Thread: How to remove AE86 Rear Bumper
    Junior Member Domestic Engineer Sprinterboy's Avatar
    Default How to remove AE86 Rear Bumper
    Ok, for those of you that don't know hear is a little walk through on how to remove the stock rear bar off your sprinter (aus spec)
    You need to undo the bolts atop of the mudflaps and also take off the mud flaps(if fitted)
    Now thats done pull up carpet(if you still have it) and remove the four (in total) rubber plugs
    Now you will need an 19mm soket with extension to undo these as they are pretty tight, we also used a bit of leverage to help
    Default Re: How to remove AE86 Rear Bumper
    Now you've done that there are two more, one on either side behind the trimming
    Hear is a pic with the bolts removed
    And finally with a little wiggle you should be able to pull it off!
    Thanks to toysprinta for it's his car in the pic's.
    AE86 Tuning Life Backyard Mechanic Garth AE86's Avatar
    Sydney NSW
    good little article for the noobs!
    rep+!
    Garth - 100% AE86 Addict
    AE86 - Levin & Trueno - The Legends Live On!
    'AE86' - Toyota Sprinter Trueno GTV
    "It's not a street car if you can't drive it on the street. The car has to be safe and fast on any road condition" - Keiichi Tsuchiya
    By The Witzl in forum FAQ
    Last Post: 12-02-2018, 12:26 PM
  2. Suspension for dummies
    Last Post: 13-09-2007, 07:38 PM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
