Results 1 to 2 of 2
Thread: 1988 MA70 Toyota Supra Turbo A - $14,000
    Nov 2009
    Default 1988 MA70 Toyota Supra Turbo A - $14,000
    VIN No: MA700107892
    Engine No: 7M0200089
    142,000kms on the body (Engine Rebuilt at 118,000kms)
    Engine Details:
    Orginal 7MGTE
    Orginal CT26-E
    Engine machined and fitted with all new plugs, rings and bearings etc.
    Eagle Rods with ARP Rod Bolts
    ARP Head Studs
    ARP Main Studs
    HKS Metal Headgasket 1.2mm Bead Type
    Driftmotion Upgraded Oil Pump with AZ Performance Oil Pump Pipe
    New Waterpump
    New gaskets and a lot of hoses changed to softlines.
    Head reconditioned with 3 angle grind and clearances set.
    Titanium 3" Exhaust
    (Please refer to photo of spreadsheet for more details)
    Transmission:
    R154 5 Speed Manual
    Action 6 puck ceramic/metallic sprung clutch
    New Pressure Plate
    Marlin Crawler Urethane Shifter Bushes
    Marlin Crawler Shifter Socket
    ARP Flywheel Bolts
    New Bosch Starter Motor
    New Clutch Master Cylinder
    New Clutch Slave Cyclinder
    New Speedo Cable
    To much to list about this car. Also comes with two boxes full of original & spare parts.
    Mechanically it runs like a dream and as you could imagine the owner has spent a fair bit of money ensuring its reliability.
    Bad points are the car is not immaculate, as you can imagine it is nearly a 30yr old car, has paint fade on the roof, swirls, scratches and scuffs. Also the leather on the driver’s seat and center console has cracked. Tyres will also need to be replaced.
    Car will also come without reg & rwc. It is still drivable and can be driven with a permit.
    I have a ton of paperwork here, receipts, invoices, documents, emails etc.
    Genuine enquires only please.
    Asking Price $1,4000
    Best to contact on 0412 876 885 or via PM.
    Nov 2009
    Default Re: 1988 MA70 Toyota Supra Turbo A - $14,000
