Results 1 to 3 of 3
Thread: 4AGE shim Adjustment
    Jan 2007
    Default 4AGE shim Adjustment
    First time I've done this with cams in-situ. . .
    I bought the correct tool (copy of Toyota / Lexus OEM) but cannot remove shim as the hold-down tool itself stops shim coming out.
    Releasing & grabbing the shim from the follower is not the problem - the issue I have is that there's just not enough clearance between the head casting (under the cam bearing cap) and the hold down tool for the shim to move through - it's simply too narrow.
    I really DON'T want to remove the camshaft but can't see how to avoid this unless I can work out how to hold the follower down at the back/outer side of the camshaft.
    Can anyone tell me what I'm doing wrong? < refer photo below >
    http://i1062.photobucket.com/albums/...GE_Shim_1b.jpg
    oregon
    Default Re: 4AGE shim Adjustment
    its difficult, but I use the holding tool on the edge of the bucket closest to the journal, this allows enough room to get the shim out.
    Jan 2007
    Thanks OST; logic told me that applying the tool on the back / journal side was the only way it might work but as you said - it's bloody difficult - very little room to gain a purchase.
    Nevertheless I'll give it a shot - if that doesn't work I will loosen the bearing caps (but keep the belt on) & hopefully that will give me some extra room.
  1. Shim sizes.
    By crowncustom in forum Tech and Conversions
    Last Post: 15-04-2007, 04:11 PM
