You can add pics to your post by hosting on an external image site eg imgur and then linking to that eg use the code [IMG]weblink here[/IMG] to put it in your post
- Check body for rust. Lower corners of windscreens, sills below the doors, and quarter panels behind the back wheel are common areas for rust
- Remove and get professionally cleaned the radiator and heat core. Check heater tap for rust
- Replace all body rubbers eg suspension/steering and door seals/windscreen seals. Avoid ebay rubbers from Thailand if possible and use genuine Toyota ones as they fit better. Check with Toyota as you can still order most of these.
- replace/rebuild brake and clutch master cylinder
- rebuild brake calipers with new seals
- replace rubber brake lines
