Results 1 to 6 of 6
Thread: ST205 3SGTE engine into ST185 GT4 Celica
    Nov 2012
    Question ST205 3SGTE engine into ST185 GT4 Celica
    G'day all,
    Searched the forums and couldn't find any threads about this so I am asking here.
    I recently purchased a ST205 GT4 half cut and have been in the process of removing the engine and gearbox out of that to put into my ST185 GT4.
    Apparently the front drive shafts are different:
    ST185 drive shafts bolt onto a flange coming out of the gearbox.
    ST205 drive shafts magically pop in and out using some form of magic.
    Whats more...
    ST185 front drive shafts are 405.4mm and front track is 1475mm
    ST205 front drive shafts are 357.7mm and front track is 1510mm
    Not quite sure why this is...I thought both cars had the same gearbox. Is the ST205 box much wider? Or is this due to rim offset?
    Finally, can anyone please recommend what I should do if I wish to keep the stock ST185 suspension setup rather than switch to the super strut from ST205.
    If possible, I'd prefer to keep the 205 engine and gearbox together...just to make things easier.
    The 205 drive shafts also have the ridges for ABS speed sensor and my 185 ones don't.
    Thanks for any help that can be provided!
    Dan
    Default Re: ST205 3SGTE engine into ST185 GT4 Celica
    From memory my 185 shafts popped straight into the 205 box....no wizardry required at all?
    Nov 2012
    Oh..okay. Did you have ABS on your 185? I'm trying to figure out what to do with the big flange on the end of the 185 shafts that bolt onto the bit coming out of the gearbox.
    Or does this bit from the 185 gearbox also pop out?
    Thanks,
    Dan
    Yeah my 185 had ABS. For both boxes the driveshafts just pop out with only a C clip holding them in. A quick tap did it pretty easily most times. Seeing you should just be using your 185 shafts you won't have a drama?
    May 2011
    Ok I put a 205 motor and gbox in a 185 and ran the 205 ecu.
    Mine is non abs and the st185 shafts slide right in.
    The extra width is all in the suspension.
    Use 185 engine mounts. Cut the st205 throttle cable mount and use the 185 cable.
    Everything else is the same
    Except electronics. That's a whole different story.
    1990 ST185 Running stock Gen 3 power, 216awhp at 15psi. 13.6 second down the quarter
    Nov 2012
    Would love to hear more about your project aus jd. Do you have a write up of it somewhere?
  1. 3SGE (BEAMS) or 3SGTE (ST185/St205) into St184
    By DJS in forum Tech and Conversions
    Last Post: 12-09-2011, 06:00 PM
  2. ST185 - ST205 engine swap
    By 72 TA22 in forum Tech and Conversions
    Last Post: 04-02-2006, 10:55 AM
