Results 1 to 5 of 5
Thread: 5mge mid sump to front sump swap.
    May 2006
    tas
    Default 5mge mid sump to front sump swap.
    Hey guys,
    I need to swap a mid sump to front sump. I need to know exactly what parts I need to ask for from ol mate. Just sump pan and pick up?)
    Its for a project so it will sit for a couple of months until I can get stuck into it.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Act
    Default Re: 5mge mid sump to front sump swap.
    and possibly pump and maybe even dipstick depending on appication
    Tasmania
    Just use the sump and oil pump from a MX83 as you will need to find a MX73 to get the proper 5MGE oil pump to suit front bath sump.And yes you can use the 7M pump as I did when I was running a 5MGE in my MK2 Coupe.
    Cheers Brett.
    May 2006
    tas
    I've found a guy with a 5mge front sump from cressida. Wasn't sure if pumps where different. Found a lot of chat on people using 7m pumpa but wasn't sure why.
    -JZX83 in the build
    <3 7M sludge pump
    Tasmania
    The pickups are in different spots.The reason why I used the 7M pump was because the pickup on the Cressida 5MGE pump had a locating dowel for its pickup that wouldn't line up with the mid sump pickup.
    Cheers Brett.
