Chosen as a factory tyre for premium sports cars such as Ferrari, Aston Martin and Lexus, the Potenza S001 is the ultimate high performance tyre. With new optimum block rigidity offering improved traction and braking performance, it combines high-speed capabilities with a more comfortable ride in all conditions.
• The ultimate in high performance
• Exceptional handling, precision and response
• Supreme control and grip in the wet and dry
• Enhanced braking performance in the wet and dry
• Quiet, comfortable ride
• Next generation run flat technology fitments available
The Potenza S001 has proven high-speed stability, superior handling in both wet and dry conditions and great braking performance. Bringing Bridgestone’s innovative tyre technology into a premium tyre that maximises performance in high-end sports cars, its features bring many benefits to the driver including:
• Semi-slick centre rib for improved handling
• Slanted lug for enhanced traction and braking performance
• 3 main grooves for water evacuation and improved wet performance; anti-hydroplaning
• Wide outside shoulder for increased tyre rigidity and improved dry performance and handling
• 3 new heat controlling technologies for improved ride comfort and reduced heat generation
The ultimate in driving comfort with smoother handling and reduced noise. Strengthened casing improves handling and ensures a ride that is as comfortable as appropriately sporty for high performance cars.
With regular tyres, a puncture generally means you lose steering control. With run flat tyres*, if your tyre gets punctured, there’s no sudden deflation – meaning you can continue driving safely. The Bridgestone Potenza S001 features a selection of run flat fitments for cars fitted with a TPMS (Tyre Pressure Monitoring System). This revolutionary tyre technology allows you to maintain control and drive safely on a punctured tyre.
The new generation run flat technology on the Potenza S001 features a thinner sidewall and new heat suppressing technologies to limit tyre distorting, resulting in improved safety and ride comfort.
*An on-board tyre pressure monitoring system is mandatory for all run flat tyre fitments and currently they're only fitted to certain late model vehicles
For more information on available sizes, feature and performance ratings for the Potenza S001 visit: https://www.bridgestonetyres.com.au/potenza-s001
To find your local Bridgestone Store and get a quote visit: https://www.bridgestonetyres.com.au/bridgestone-network
