Results 1 to 9 of 9
Thread: Getting a key cut without the original
    Junior Member 1st year Apprentice psi1uz's Avatar
    Default Getting a key cut without the original
    Is it possible to get a key cut for an ms85 crown without the original? I want to buy said vehicle but the owner has lost the key.
    Default Re: Getting a key cut without the original
    Easiest way I believe, is to remove the door lock / barrel and take that to a locksmith...
    Apr 2007
    As wa5 said, only thing is make sure the door barrel lock uses the same key that is used in the ignition barrel
    Jan 2008
    With My AW11 I had no key when I bought it. There is a code number on the drivers door lock and just gave the locksmith that. he just punched in the code and 2 keys and $36 later two perfect keys not copys of worn ones.
    Apr 2007
    Generally with older cars the manufacturers didn't have the foresight to do that ..
    Jan 2008
    Spose, its 10 yrs older. Just have to look and see?
    Tasmania
    The MS85 should have the number stamped on the key barrel,my MS55 does and so does my RT40 and most of the other Toyotas I have owned over the last 30yrs have.
    Cheers Brett.
    Thanks heaps fellas. Looks like I'm getting an ms85 ☺
    Nov 2007
    Some locksmiths are able to make a key from scratch to fit any Barrel. I know one in Perth who did this for me, very impressed.
