Results 1 to 5 of 5
Thread: Corona MX10/12 wiring help
    California
    Default Corona MX10/12 wiring help
    Hi all,
    So I've got this old car that I've swapped a 7M-GE into. I'm down to just a few wires I can't figure out. As no one in the U.S. actually has one of these cars, ya'll are the best source of info.
    So this is where I'm stuck. I can't figure out these wires. Anyone out there with a Corona MX10/12/13/22/23 can help?
    I think these three wires plugged into the Corona alternator. This plug is over by where the alternator on the 2M was
    This large white wire. I think it's one of the primary power wires. It has 12v when the key is on. Not sure what to do with it. For location reference, this wire is right next to the heavy red wire for the headlights
    If you want to see my build thread, click the link below
    http://japanesenostalgiccar.com/foru...hp?f=9&t=24037
    Tasmania
    Default Re: Corona MX10/12 wiring help
    Ok I may be able to help as I have done this to a MX13.The first lot of wires are for the original Nippon Denso Alternator which you shouldn't need as you will have to make up another loom to run the 7M Alternator.The thick white wire is main battery power but as your car is LHD Im unsure as Im in Australia but it could be the wire for the output terminal on the alternator if its on the same side as where the original 2M alternator was.As to your starting issue go back and use the factory wiring to the starter and the new wire that you have used for the starter needs to be fed back to the factory starter wire as this also includes the start signal wire for the ECU for memory.
    Cheers Brett.
    Nov 2011
    those three alternator wires will go to an external voltage reg
    this reg will have 6 wires
    3 will goto that plug in your pic
    the other 3 will most probably be
    one should be ign power
    one will be battery
    one will be charge light
    extend these to the 7m alternator plug
    California
    Quote Originally Posted by crowncustom View Post
    Great thanks
    On the other side of the car is also a heavy white wire that I hooked up to the battery as the main alternator output. Along with the 3 wire plug in the first photo, you're right, that's where the 2M alternator was. So I'm thinking the heavy white wire pictured above is the other end of that wire. Does that loop back into the alternator "sense" wire?
    Cheers Brett.
    Thank you
    California
    Quote Originally Posted by dumbass View Post
    one will be battery
    Terrific! Thank you!
  1. 1972 Corona(MX10) MK2 advice from owners/enthusiasts
    By corona mk2 in forum Tech and Conversions
    Last Post: 18-07-2011, 06:45 PM
