Results 1 to 6 of 6
Thread: W58 Into ra23 celica
    Jun 2012
    Default W58 Into ra23 celica
    Hello all,
    I was wondering if a wa58 is a direct bolt in to a ra23 celica? I know the bellhousing bolts up directly but does it mount in the same places? Also is the shifter in the same position?
    Thanks
    The old One Backyard Mechanic
    Default Re: W58 Into ra23 celica
    The W58 comes with several shifter positions. Sooo it depends on which one you have. Take a tape measure to it
    Jun 2012
    I don't have the gearbox yet i want to do the conversion sometime soon. Thanks for the info i'll keep that in mind when i buy one.
    Do you know if they mount in the same place as the W50?
    why are you upgrading if you are keeping your 18r? im pretty sure they use the same bolting locations, at least they look very close, i have both down stairs standing beside each other.
    The cross member mounting is a little further back on W5x series, very simple mod. Other than that if you get the 18" position selector housing they bolt straight in with the 22R bellhousing.
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
    Jun 2012
    I was informed that the W58 was stronger than the W50 and the ratios are slightly more what I am after plus the whole transmission is a lot lighter.
