Fuel pump supplies fuel, fuel regulator regulates the pressure.
There's 3 things to check here, the voltage at the pump, the pump and the regulator.
Wat did u do to confirm the pump is fine? Maybe as the motor demands more fuel, the pump can't keep the flow and pressure up.
Maybe the pump is internally failing under load. There's a couple things it could b, changing the fuel pump is one way of eliminating it as a cause, the other is changing the fuel pressure reg, both are a pain in the ass tho.
