Results 1 to 2 of 2
Thread: crossmember to fit w50 to RA21 chassis
    Nov 2012
    Wa
    Default crossmember to fit w50 to RA21 chassis
    Im fitting a w50 to my 18rc equiped RA21, and I'm noticing the crossmember for the w40 it came with does not match up. is there a crossmember for the w50 that fits the w50 to an RA21 chassis, and if not has anybody modified one to fit?
    Thanks for any help in advance, this is holding up the project. I was planning to test out the transmission before my 18rg build was finished.
    Default Re: crossmember to fit w50 to RA21 chassis
    W40 and W50 gearbox's are interchangeable in Toyota Crowns of the same era as your Celica. No change in crossmember positioning, no change in gear selector location.
    Just wondering if you have tried a crossmember from an auto trans version of your car. I know that on the early Celica's 1972 -1975 that auto crossmember, and a couple of pieces of 2" x 1/8" angle iron is all that is required to change from a T50 manual to a W series box, as the bigger box sits further back. You simply bolt the crossmember to the angle iron and the angle iron to the chassis, job done,
    cheers Chuck.
    MS51Crown Coupe,
  1. RA21+Altezza 3S, which swaybar?
    By ryojikaji in forum Tech and Conversions
    Last Post: 26-02-2012, 03:29 AM
