Results 1 to 8 of 8
Thread: Help on 3s-f motor.
    Toymods Club Member #302 Backyard Mechanic hi-ace's Avatar
    Default Help on 3s-f motor.
    Hi, as you might know my daughter inlaw has a Holden Apollo with the 3s-f 2lt 16v carby motor in it.
    Ok, the problem is I changed the plugs for her today and the pots where the plugs are would have been near 1/2 full of oil.
    I know this is WRONG, so I have ordered the seals and a rocker cover gasket. Is there anything I should know before I start to replace this stuff.
    Any info that might help, would be a great help thank you.
    Thanks in advance.
    If it feels good "DO IT" Unless it harms others.(or upsets the RTA)
    Enjoy what you have To Day,cause you can't take it with you.
    My old Hi-Ace
    Rosewood
    Default Re: Help on 3s-f motor.
    It is a straight forward gasket swap, nothing to really get your caught up.
    Although in the BGB, it states to use some sealeant in and around where the cover melds over the cam. So it gives a better seal.
    Junior Member Grease Monkey Cruiser97_80's Avatar
    Tasmania
    spark plug tubes filling with oil on these engines is usually caused by the engine oil leaking past the threaded section of the tube. i.e. where the tube screws into the head.
    Remove rocker cover, unscrew tubes, clean up the threads and apply thread sealer to the tubes thread before reassembling...
    cheers.
    1990 ST185 GT4 3SGTE
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    1998 ST215 GTT 3SGTE
    2008 VDJ200 Sahara
    Thanks for the input guys.
    My old Hi-Ace
    Junior Member Grease Monkey johnny blade's Avatar
    Sweden
    I think someone have filled her up with oil and missed the oil filler hole.
    I wish it was that simple. but they are covered untill you take the plug leads off.
    My old Hi-Ace
    yes rocker gasket . just make sure he surfaces are clean and dont tightern to much!
    to clean out, pour a little petrol in each one, then use a rag and screw driver to get it all out.
    Ok, jobs done. I think who every had the rocker cover off last time must have used bloody near 1/2 a tube of silicon when they put it back on.
    I had to drill a hole through the tubes to get them undone, so the tubes got replaced to.
    My old Hi-Ace
  1. V6 4-Runner Knocking Noises in 3V-Z motor...Help Needed
    By Toyo Truck in forum Tech and Conversions
    Last Post: 05-04-2006, 09:38 AM
  2. Tips on replacing the starter motor in an RA65
    By azmodai in forum Tech and Conversions
    Last Post: 22-12-2005, 05:12 PM
  3. 20v starter motor
    By Selk in forum Tech and Conversions
    Last Post: 19-12-2005, 08:08 PM
  4. Replies: 3
    Last Post: 16-10-2005, 09:32 AM
