Results 1 to 14 of 14
Thread: jzz30 auto to manual conversion
    ------------------------- 1st year Apprentice RIPSIP's Avatar
    Default jzz30 auto to manual conversion
    In the final stages of converting my jzz30 from auto over to manual. (fitting a new turbo, fuel injectors, fuel pump, cams, etc.)
    Q: Now that it's manual is there a HKS power FC i can use with the auto computer? if not what other options do i have to tune the engine? some help would be excellent especially if someone has experience with a jzz30 auto to manual conversion!
    Roll Ons? Carport Converter Endless's Avatar
    Default Re: jzz30 auto to manual conversion
    You'll find that the Power FC for jzz30 is a standalone ECU, which will require you to completely remove the auto ECU that is in there now.
    Ok so there should be no problems then right? just chuck the auto ECU and plug in a 1JZ Power FC. But in Getting rid of the stock ECU will i lose any other controls
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Hi mate
    You need to find out if the power fc is for a auto or manual JZZ30. Cos the harness to ecu plugs are different. You having an auto harness trying to put a manual power fc in will not work.
    1994 GZX90 Mark II 1GZ-FE V12
    I dont think HKS made a power FC for the Auto soarer? (Thats why i was wondering if the manual would fit) Guess im back to square one. I can always just stick with the Apexi S-AFC II & S-AVCR but it will never be as flexible as a stand alone ECU Replacement! Q: Any other stand alone ECU's upto 5k worth looking at?
    The haltech E11 v2 is supposed to be pretty good. Thats what i'm putting on my 2jzgte.
    I've done the same coversion on my Soarer and i dont think the difference in the looms is too major. If you look in the A'Pexi wiring diagrams for the SAFC and AVCR they both use the same wiring diagram for the auto and manual ecu. Plus can't you change the stock auto ecu to a stock manual ecu without any re-wiring so wouldnt that mean the power FC should be no different
    JZZ30, manual + GT3040 =
    Quote Originally Posted by tyottsoarer
    That's exactly what i was thinking as Power FC's only come in auto for the JZX100.
    Quote Originally Posted by triptek
    Doesn't that mean you couldn't swap a stock auto ecu to a stock manual ecu without major re-wiring? Please excuse my ignorance when it comes to electronics I really am in the dark quite a bit? I really want to get the tunning perfect!
    Yeh that would mean you couldn't swap the ecu without swaping the harness aswell.
    Just contacted my local performance shop and he confirmed that the power fc are only for the manual soarer's. I think you'll have to go for a complete wire in ecu.
    Thanks for your help guys. Was hoping to use a Power fc but Think i will go the ezy route leave the stock auto ecu and just wire in the Apexi S-AFC II & S-AVCR and control fuel/air ratios and boost that way! bit scare to rip out all the wiring looms; sounds like a very time comsuming and expensive deal!
    Cheers Guys.
    P.S: if you here of a way that doesn't involve ripping out all the wiring harness would love to hear about it!
    I have a 2jzgte map sencer and injectors if your interested.
    I've already bought 850cc sard injectors, but thanx for the offer!
    Ecu plugs are the same.
    Power Fc will work!
    Just plug it in.
  1. MA70 --> JZA70 Conversion
  2. MZ20 / MA70 Auto - Manual conversion
    By Disturbed1 in forum Tech and Conversions
    Last Post: 12-04-2006, 07:49 PM
  3. GZ20 auto to maunal conversion
    By Big rob in forum Tech and Conversions
    Last Post: 03-03-2006, 06:15 PM
  4. Ma61 auto to manual conversion
    By Mattrt142 in forum Tech and Conversions
    Last Post: 22-02-2006, 07:13 PM
