Results 1 to 2 of 2
Thread: Lay shaft bearings
    Dec 2011
    Ohaupo
    Default Lay shaft bearings
    Hi ,
    I am trying to locate parts numbers for layshaft (Jackshaft) bearings for 18RG and 3T , can any one help please ? Toyota NZ can no longer supply
    Default Re: Lay shaft bearings
    Hi there mate,
    May I assume you are looking for bearings for the dummy cam come oil pump drive shaft in the twin cam engines which replaced the camshaft used in the original pushrod engine...?
    If so then the bearings belonging to the NON twin cam versions can be happily used as long as the ones without the shaft going through them are turned 90 degrees or so to ensure the oil gallery holes are blocked.
    The original 3TGTE or 2TG dummy shaft bearing part number appears to be 11022-27011.
    Jason
  1. Replies: 8
    Last Post: 02-11-2013, 06:49 AM
  2. Replies: 0
    Last Post: 31-01-2012, 12:37 PM
  3. 7AG using RB26 bearings?
    By oldcorollas in forum Tech and Conversions
    Last Post: 10-06-2008, 11:44 PM
  4. 5M bearings
    By johnny blade in forum Tech and Conversions
    Last Post: 25-09-2006, 06:25 PM
