u got yr speed sensors confused
sp2+ sp2- should have a 4 pulse signal per rev of the output shaft and be 2 wires
this goes directly to the ecu
the 3 wire speed sensor goes up to the speedometer then signal goes from speedo back down to ecu to terminal called spd or sp1 pink wire or purplewhite wire
if your speedo reads correct then the signal to spd or sp1 should be ok
but u have to make sire u got a 4 pulse per rev of outputshaft on sp2+ sp2-
i stopped using the jaycar speedo correction units as to hard to get working perfect
i either use dakota digital ones or another type i buy from china which are very good
