Results 1 to 10 of 10
Thread: Big problem with ta22 3t turbo conversion
    Nov 2009
    Default Big problem with ta22 3t turbo conversion
    Well ive hit my first problem with this conversion and its a big one, the external wastgate on my setup hits the crossmember,
    this bit
    hits here
    now cutting into the crossmember and getting it engineered is the last thing i wanna do, are there any other ways to get around this, i cant move the wastgate because that means id have to make another exhaust.
    it came out of a ke20 so it obviously fits a ke20 crossmember, can a keXX xmember fit a ta22?
    Any help would be much appreciated!!
    Callum
    Nothing but a Backyard Mechanic caam's Avatar
    Apr 2010
    Default Re: Big problem with ta22 3t turbo conversion
    Cut and shorten the runner to the waste?
    Looks like you have an easy inch there to loose going off the photo.
    SR20DET TA23
    Oct 2009
    Easy one, either shorten the piping or move the wastegate
    Nov 2009
    yes i know but if i move the wastegate i have to make or heavily mod the exhaust i already have for it, the current one bolts onto both the turbo and the wastegate, which keeps it quiet.
    Apr 2007
    As you have said i wouldnt touch the crossmember either, so going by the not so clear photo its either play with the exhaust & waste gate or maybe get another turbo with a inbuilt waste gate, but it wont just bolt up either ..
    Apr 2010
    Meh it wouldn't have to be 'heavily modified' take it to an exhaust shop if you're not confident and say I want to shorten this and join these. Easy
    SR20DET TA23
    Aug 2009
    big problem LOL
    LOL, your doing an engine conversion and concerned about doing a mild mod to the exhaust? KCCO bro, life is good, either chop it and weld it yourself, or bolt it all in with the gate off and get the exhaust modded by a good fabricator or any run of the mill exhuast shop
    Shift wastegate upwards, blend outlet to dump via flex exhaust section?
    Nov 2009
    yeah i was a bit if a hypercondriac when i made this thread ahaha, ive taken the exhaust side off the engine and im taking it to a local exhaust shop so they can move the wastegate up an inch or 2
  1. MZ20 aerocabin manual conversion problem
    By 5m3g_head in forum Tech and Conversions
    Last Post: 29-10-2011, 07:01 PM
  2. problem after conversion 7m-ma61
    By Azzamk2 in forum Tech and Conversions
    Last Post: 17-03-2009, 06:02 PM
  3. omfg. 1g problem has carried over to 1jz after conversion :(
    By pato in forum Tech and Conversions
    Last Post: 03-08-2007, 08:19 AM
