Results 1 to 9 of 9
Thread: MRP 4age Turbo Exhaust Manifolds RWD & FWD
    Forum Sponsor Domestic Engineer Bazda's Avatar
    Jul 2008
    Auckland
    Default MRP 4age Turbo Exhaust Manifolds RWD & FWD
    Hey Guys,
    As usual we are always making custom 4age items!
    We have available RWD & FWD manifolds. We keep a few in stock but generally made to order.
    Both FWD (Suit all AE chassis) & RWD (AE86/KE70/KP61 plus other RWD engine bays)
    We also now have available 7afte
    Manon Racing Products - New Zealand
    $675NZD
    That gets you a single entry manifold VHT coated with wastegate port. Divided setups are an extra $150NZD
    Coatings are extra (They come sandblasted and painted in high temp VHT free of charge), we have the normal shiny Ceramic coating rated to 700C which is $140NZD, Satin black rated to 1000C is $170NZD
    Shipping to Aus is approx $70NZD
    Flange suits both 16v/20v heads
    Equal length runners
    Ram Horm Style to maximise runner length
    Long low angle merge collector to maximise flow into turbo
    Material - 3.7mm Steam Tube SC40
    Coatings - Optional Ceramic (700C) or Black Satin (1000C)
    Turbo Flange - All flange types available please specify on cart check out (T25/T3/T4/T3 Divided/T4 Divided/TD05 etc)
    Fully TIG welded
    12mm Thick Flanges
    M10 stainless steel studs & nuts provided
    Optional wastegate port to suit 38mm 2 bolt Tial style - Must supply wastegate flanges if another type
    Divided Flange Setups:
    When using a twin scroll ex housing setup the runners are placed in the correct firing order to maximise the pulsing of the cylinders. This system is more complex to build which requires either 2x wastegate ports or a 2-1 wastegate setup.
    2 Model types available for FWD:
    Non Air Con setup - Turbo compressor housing faces cam belt side of engine meaning shorter IC piping can be done.
    Air Con setup - Turbo compressor housing faces gearbox side.
    Both models fit with Power Steering
    1 Model Types for RWD - Top Mount, compressor angled facing towards head light. Works with all dizzy setups but its better to use coil packs on turbo setups.
    All Manifolds come with a 10 year no crack warranty
    If the model you choose is not in stock there is a 1-2 week lead time.
    We can custom make to suit your requirements as well.
    Now 9AGTE 410kw atw
    Toymods Club Member Domestic Engineer
    Oct 2009
    Default Re: MRP 4age Turbo Exhaust Manifolds - Finally!
    Any plans for an AW11 manifold?
    Jul 2008
    Auckland
    Quote Originally Posted by foamy View Post
    I think the AW11 needs a flatter style, the ram horn style prob wont fit.
    I can easily make one though! just need to get someones AW11 so I can make a jig.
    Now 9AGTE 410kw atw
    Oct 2009
    AW11 version would be awesome, any idea till you will have one made?
    Jul 2008
    Auckland
    Quote Originally Posted by dnegative View Post
    Woring on the FWD models first, then the RWD top mount. Then after that will do the AW11 version. Unless someone really wants to buy one now I could fit this in after the FWD stuff.
    Now 9AGTE 410kw atw
    Oct 2009
    I'm not in a rush for one but when you get around to making them I'll probably take one off your hands.
    ethanol sniffing Backyard Mechanic adamaw11's Avatar
    I too would be interested in an aw11-suited turbo manifold in the next few months or so.
    NA: [email protected] at willowbank. On E85 with 6psi boost: [email protected] ~8psi: 13.187 @169.9kmh. >10psi: 12.9 rod fragments @ 174mm holes in block
    daily: '93 ae101 Levin coupe. Motorbike: '09 Suzuki GSR600: [email protected] at Willowbank
    Jul 2008
    Auckland
    Currently making RWD versions.
    FWD ones are up next, we still need to find someone in NZ to test fit to the AW11 and go from there.
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    Default Re: MRP 4age Turbo Exhaust Manifolds RWD & FWD
    7afte is now available.
    yet to test fit into the AW11 our FWD version.
    Now 9AGTE 410kw atw
  1. 4age turbo exhaust manifold
    By Thirteen13 in forum Tech and Conversions
    Last Post: 03-10-2011, 10:32 PM
  2. FWD 4age turbo manifolds,, anyone make them??
    By 4AGZE_rolla in forum Tech and Conversions
    Last Post: 25-07-2007, 05:13 PM
  3. FWD 4age turbo manifolds,, anyone make them??
    Last Post: 03-06-2006, 12:24 AM
