Results 31 to 45 of 49
Thread: 4age/ze - Race Harmonic Balancers from $320
    Jul 2008
    Auckland
    Default Re: 4age/ze - Race Harmonic Balancers from $320
    Quote Originally Posted by andrew_mx83 View Post
    Hi barry can you please get me a price for a 2 row, 5pk x 135mm harmonic balancer with a 35.10 ID
    Let me know if you need more measuments or a sample (suit 7m)
    Thanks
    We would need a unit to send to these guys. You wont be able to use a 4a one as these guys design the dampers depending on the engine.
    Now 9AGTE 410kw atw
    Moved to pm to keep your thread clean
    Never late in an x8
    Feb 2010
    Auckland
    Hey Barry, when do you need to confirm orders by?
    Jul 2008
    Auckland
    Quote Originally Posted by Stolic View Post
    I already have on order the single row and dual row pulleys 4age.
    Nothing on the 4agze yet as they are still designing this.
    Now 9AGTE 410kw atw
    Feb 2010
    Auckland
    Quote Originally Posted by Bazda View Post
    Arseburgers... just found that my supercharger ain't gonna cut it, so I'll only need a single row after all :/
    Toymods Board Member Grease Monkey HJ60's Avatar
    Aug 2008
    I really wish i was still going GZE/GTE / Twincharge so i could run one of these!
    Will pass it onto a friend!
    Junior Member Conversion King
    May 2010
    Any word on the 4AGZE ones yet Bazda?
    Engine will be going to the shop soon so hoping to give them a crank pulley so rotating mass can be balanced.
  8. #38
    Jul 2008
    Auckland
    Hey,
    No word yet. I want them to finish the 4age double row before they tackle the 4agze. Its not just a matter of making the inner pulley bigger. They need to be tuned properly.
    Have the SC pulley loadings on there also changes alot of factors with the design internally. These guys do things properly!
    Now 9AGTE 410kw atw
  9. #39
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Hey,
    No word yet. I want them to finish the 4age double row before they tackle the 4agze. Its not just a matter of making the inner pulley bigger. They need to be tuned properly. Have the SC pulley loadings on there also changes alot of factors with the design internally. These guys do things properly!
    Bazda, this makes good sense, however it is going to mean they'll need to get their hands on a 9A engine (with your stroker crank) to do testing and remove guestimation from a "9AGZE" design...I can appreciate tuning is critical for an effective damper.
    For the double row on offer currently, assuming I had a smaller supercharger pulley on a 4AGZ I'm guessing the belt alignment would be ok?
    Nick.
    == 4AGZE SC14 Supercharged ==
  10. #40
    Jul 2008
    Auckland
    They dont need my engine to do the tuning as such. They use calculations.
    But from 4a to 9a crank there isnt a huge difference.
    Now 9AGTE 410kw atw
  11. #41
    May 2010
    Hey,
    Cheers Bazda, I'll hold out a little longer. Last thing we want is another inferior GZE pulley, as mentioned before no one has produced a good one in a while now!
    Are there any plans to sell this with an accompanied undersized idler pulley? If not apparently V6 camry ones are suitable with 4mm of washers shimming it out.
  12. #42
    Jul 2008
    Auckland
    I will supply a custom idler pulley.
    Now 9AGTE 410kw atw
  13. #43
    Jul 2008
    Auckland
    Quote Originally Posted by nick.parker View Post
    I would say 170mm.
    This basically spins the SC at its 10k rpm limit at engine redline ( 170/125 x 7500rpm = 10,200 supercharger rpm )
    Nick, we are going to start on the 4agze pulleys, is 170mm measured from the top of the ribs or inner?
    Now 9AGTE 410kw atw
  14. #44
    Canterbury
    Hi Barry,
    That's measured from the peaks rather than the valleys.
    Cheers, Nick.
  15. #45
    May 2010
    Great to hear Bazda, I ended up delaying a lot of my rebuild but with budget coming back in my favor, I'm looking at post xmas going into the shop. 170mm sounds about right to me for max speed, others deliberately allow the SC to overspin so you get more gain down low, but with the SC12 becoming more and more antique, I'd expect a safer RPM whilst keeping higher psi would be more desireable.
    Be sure to keep us updated on when you want a deposit/payment for the GZE pulley, maybe I should like your Facebook page if it's more convenient?
  1. AE82 and AE92 Harmonic Balancers : Are they the same?
    By Grega in forum Tech and Conversions
    Last Post: 18-03-2008, 09:18 AM
  2. crank scrapers- anything in it
    Last Post: 04-09-2007, 04:09 PM
