Results 16 to 30 of 49
Thread: 4age/ze - Race Harmonic Balancers from $320
    Junior Member Conversion King
    May 2010
    Default Re: More 4age goodness - Harmonic Balancers & Crank Scrapers
    GZE pulley is just a dual row 4AG pulley but the inside row diameter is different to accommodate the SC.
    Harmonically dampened GZE pullies are hard to come by and only second hand, new ones like T3 are aluminum only. 175mm would be great but requires a smaller idler pulley also. T3 recommend a 4AG NA alternator pulley, flipped backwards and shimmed out a touch. Otherwise 164mm is the largest bolt on upgrade without any further modification.
    Not sure if there's much market for them since 4AGTE is a common conversion these days, but if you wanna make a batch I'll definitely put my hand up for one.
    Jul 2008
    Auckland
    Quote Originally Posted by maj View Post
    Yep will look into it and get some pricings.
    Now 9AGTE 410kw atw
    Feb 2010
    Auckland
    I got a stock GZE pully in the shed if you need measurements etc Barry.
    I'm quite interested in that pulley with the trigger teeth & gear hanging off it.
    www.billzilla.org
    Toymods founding member #3
    Jul 2008
    Auckland
    Quote Originally Posted by Billzilla View Post
    yep will get pricing up as soon as everything is finalised.
    Now 9AGTE 410kw atw
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    A 'dual key' option would be go nicely with the 9A cranks...
    == 4AGZE SC14 Supercharged ==
    Jul 2008
    Auckland
    These are dual key, but thats up to you if you want to use it.
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    Bump, putting together this order now guys, let me know if you want to grab a pulley.
    There are no options yet for gilmour drives.
    We can do 4agze pulleys just need 1 to measure the diameter again as i lost all my measurements.
    Now 9AGTE 410kw atw
    Feb 2010
    Auckland
    any indication on the GZE pully $$$ ?
    Jul 2008
    Auckland
    Quote Originally Posted by Stolic View Post
    Next week hopefully!
    Now 9AGTE 410kw atw
    Canterbury
    Hi very keen on a 4AGZE one. Will it be possible to select the diameter of the supercharger part?
    (Or maybe come to a consensus that everybody goes for an over-sized unit?)
    Nick.
    Jul 2008
    Auckland
    Quote Originally Posted by nick.parker View Post
    Nick.
    What size pulley would everyone want on a 4agze?
    175mm being the largest for 14psi (then you will need a smaller tensioner pulley and a longer belt.)
    Most companies range from 165-175mm. I would prob go for the largest you can fit..
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    Default Re: 4age/ze - Race Harmonic Balancers from $320
    Pricing is up for the double row.
    Lead time is 5 weeks to manufacture.
    We can add 4agze ones if people want them!
    Now 9AGTE 410kw atw
    Canterbury
    Quote Originally Posted by Bazda View Post
    Lead time is 5 weeks to manufacture. We can add 4agze ones if people want them!
    I would say 170mm.
    This basically spins the SC at its 10k rpm limit at engine redline ( 170/125 x 7500rpm = 10,200 supercharger rpm )
    Hi barry can you please get me a price for a 2 row, 5pk x 135mm harmonic balancer with a 35.10 ID
    Let me know if you need more measuments or a sample (suit 7m)
    Thanks
    Never late in an x8
  1. AE82 and AE92 Harmonic Balancers : Are they the same?
    By Grega in forum Tech and Conversions
    Last Post: 18-03-2008, 09:18 AM
  2. crank scrapers- anything in it
    Last Post: 04-09-2007, 04:09 PM
