Results 1 to 11 of 11
Thread: 1996 RAV 4 3SGE to 3C Turbo/2C Turbo Conversion Possible??
    Feb 2010
    San Pedro
    Default 1996 RAV 4 3SGE to 3C Turbo/2C Turbo Conversion Possible??
    Im a little bit frustrated with the fuel consumption of my RAV4, it is powered by a 3SGE 2.0 N/A with a 4 wheel drive system, i have already done all the stuff and modifications to make it fuel efficient such as installing SAFC, using synthetic oil and such fluids, nitro tires, but instead it became worse. but it came to my mind of transplanting the stock engine with a diesel type, since the beginning anyone would think it is not possible, but when i encountered using a 1998 caldina powered by a 3C turbo engine, it came to my mind that it is more likely to be possible with such minor modification and conversion, from the fact that the Caldina (CT197) and Rav4 shares the same 3SGE/3SFE powerplant, and when i looked at the way the 3C engine is mounted on the caldina it is likely the same mounts, but i guess i am not too sure since it may require proper measurement and positioning.
    Anyone have already done this conversion?? any inputs or suggestions?
    here's the sample image of the 3C turbo engine:
    Here's the engine bay of the CT197 Caldina diesel:
    Here's the engine bay of the Rav 4 powered by 3SGE:
    Default Re: 1996 RAV 4 3SGE to 3C Turbo/2C Turbo Conversion Possible??
    Just so you know, that's a 3SFE, not a 3SGE
    Feb 2010
    San Pedro
    Quote Originally Posted by Hiro View Post
    oh yes, my mistake.. that's a 3sfe. but still shares the same mounts, tranny and engine bay positioning. right?
    Victoria, Mt Macedon
    I think you would have to drive huge distances for the fuel savings to make it worthwhile doing an engine swap. It will still be a largish 4WD with the diesel engine. So if you want to spend less on fuel either drive less or buy a smaller, more efficient car.
    If you want an interesting project and can deal with this car being off the road for a few months then by all means do the motor swap.
    Automatic 3SFE with a bogey SAFE in a RAV4 not being very fuel efficient? Just think about that for a minute...
    As for the engine sway, just trade in the RAV4 on a VW Tiguan diesel and save yourself the bother.
    Lpg?
    10char
    Never late in an x8
    if you installed SAFC and fuel economy became worse... than maybe it is not tuned correctly?
    have you checked that your Oxygen sensors are working?
    or change driving style?
    how much fuel does it use per 100km?
    my caldina 3SGTE turbo (1470kg) uses 9.1-9.2L/100km with half highway use.
    Junior Member Grease Monkey stealth's Avatar
    Jul 2012
    Manual conversion?
    But seriously... Even if your SAFC is poorly tuned how bad can it be?
    Its an EFI, DOHC, NA 2.0L? You're not gonna get any better in a chassis like a rav 4...
    Get a motorbike if you wanna save on fuel. $25 gets me 400kms...
    JZA63 Celica 13.9 @ 162km/h
    Toymods Board Member Grease Monkey HJ60's Avatar
    Aug 2008
    RAV4's have never been the most fuel economical vehicles, but I'm sure you're aware of this!
    Manual Conversion will help - I'd do that before spending all the money converting it to Diesel!
    Nov 2007
    Don't forget that a diesel will require different gear ratios also. Not sure if just changing the final drive ratio would suffice or if you would different gearbox ratios also. Either way I'd be interested in seeing a build thread on this. My '99 RAV would be alot more fun if it had a diesel. The 3SFE works way too hard to pull it along which is probably why it uses so much fuel.
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
    Swapping in a 3C engine will cost how much $$s?
    How many KMs of driving at a tiny bit cheaper fuel price will you have to do to make the conversion worth it?
    Same goes with any other mods you do.
    I bet it'll take 5+ years of driving to start making that conversion worth it.
    If you seriously need to save $$s on fuel, sell the RAV4 and buy a Corolla.
  1. Turbo pistons for 3SGE Beams?
    By Toycrash in forum Engine & Driveline Conversions
    Last Post: 15-07-2014, 08:41 AM
  2. Travs 3SGE +turbo RWD conversion
    By TRAV-KE55 in forum Tech and Conversions
    Last Post: 08-09-2010, 08:50 AM
