Interested!
Though unsurprisingly I don't need the full kit.
Just the pump (only with the scavenge sections please), the tank, the sump, and the pulleys & belt please.
Hey Guys,
This is most likely the most complete kit on the market, all you have to do is add a oil filter relocation block, and plumb the system.
$3850NZD gets you all the listed below.
If you dont require power steering setup its less $150NZD
The kit will contain the following:
- 3 Stage custom made dry sump pump made in USA
- Pump bracket (We can supply brackets to suit where ever you want to install the pump just let us know)
- Custom Moroso sump with -12AN ports
- 2 Gallon Peterson aluminium tank with brackets
- 2x -12AN Moroso Screen filters
- Moroso breather Can
- Moroso oil filter block off plate
- Moroso adjustable vacuum relief valve
- Vacuum gauge
- BHJ High Performance Harmonic Balancer
- Moroso HTD Drive Pulley
- Moroso HTD Pump Pulley
- HTD Belt
- Custom Drive mandrel
- Custom HTD PS pump pulley
- Pump Idler tensioner with bracket
AN fittings & braided line is extra cost. But we can get fittings at good prices (Around $30NZD a fitting)
Now 9AGTE 410kw atw
Interested!
www.billzilla.org
Toymods founding member #3
Any Plans to make anything similar for the 3SGE Blacktop Beams motors ? ^.^ More Sump Clearance would be lovely! Not to mention the other advantages of a Dry Sump.
awesome idea!
would be all over it if it was beams though
So you want the pump but not a complete one, therefore it would be open..or do you want a complete scavenge section which you can attach the pulley to. Im assuming you have another external pump?
As for 3sge - We will be working on this kit after we complete the 4age kits, then moving right through the Toyota range of engines!
Now 9AGTE 410kw atw
www.billzilla.org
Now 9AGTE 410kw atw
www.billzilla.org
Guys actually looking at this we can do a 3sgte Moroso dry sump. Not sure if its the same bolt pattern as the beams??
The kit would basically be the same but we dont have a bracket to mount the pump as we dont have a block with all the accessories installed to make one to suit.
So if the pans are the same bolt pattern etc I can do the kit minus the mounting bracket for the pump.
Now 9AGTE 410kw atw
Bump, all this is under way. Parts are all on order!
Once I get them all then time to make the brackets and the PS drive pulley.
Now 9AGTE 410kw atw
Hey mate,
How are these coming along? Can your mounting plate be used without the PS bracket? How would the tension on the belt be adjusted without it? I need bits and pieces as I've already sourced a Ross pulley with HTD drive. Need:
- Pump bracket
- Vacuum gauge
Can you send me a price for these bits? Cheers.
Have you also thought about making a replacement oil pump section? Saves having to gut and seal up the stock oil pump.
Eddie.
4agte finally completed. 234rwkw @ 8125rpm. Tis fun
Hey, yes we will be doing kits without the PS as well.
The pump is adjustable like the Alternator or PS pump, has slotted holes. Also the idler pulley is also adjustable, im also thinking of putting a spring on this so it keeps the same tension all the time.
With the bracket only thing is, made to suit the off set of our setup, so might not 100% line up with the way the ross one is setup. Id need some dimensions from you. But we can supply all those parts no worries.
As for pump block off, we will supply the parts to block it off. Basically just a alloy rod when you press into the cover to block off the hole.
Will PM you price.
Now 9AGTE 410kw atw
Dry sump pumps are here, time to fabricate some billet brackets!
Moroso has just finished up the pan drawings, awaiting the final copy to approve.
Now 9AGTE 410kw atw
Update? Are these complete yet?
