Page 1 of 4 123 ... LastLast
Results 1 to 15 of 55
Thread: Moroso 4age baffled sump group buy
    Jul 2008
    Auckland
    Default Moroso 4age baffled sump group buy
    Hey Guys,
    As you know Moroso sumps are awesome!
    But they dont offer a 4age sump.
    We have worked with Moroso for months coming up with a design that will fit any 4age/7age block, RWD & FWD configuration
    To suit: 4age/7age RWD & FWD also AW11. Both Early and late model sump pattern designs
    Material: Steel Zinc Plated
    Baffles: Internal dynamic trap doors
    Volume: Extra 1L
    Ports: Oil Temp, Turbo Drain, Drain plug, Head drain
    The depth of the sump is the same as OEM, the side wings are the only part which is larger.
    The sump features a bolt in windage tray, so you can remove the OEM tray which makes installation much simpler.
    $650NZD + $75NZD shipping
    Now 9AGTE 410kw atw
    Jul 2007
    Default Re: Moroso 4age baffled sump group buy
    as per twincam. i am keen
    Jul 2008
    Auckland
    Noted down.
    Now 9AGTE 410kw atw
    Aug 2009
    Is this design for RWD or FWD?
    Rgds, Willofan
    Jul 2008
    Auckland
    Quote Originally Posted by Willofan View Post
    Yes it will fit all models.
    We will be revising the sump, this is just a quick mock up.
    Side extended parts will be smaller, and the shallow part of the sump will be shallower.
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    oops double post
    Now 9AGTE 410kw atw
    Aug 2006
    Are these going to have a oil drain port for a turbo set up or have left it blank for people to add there own?
    Jul 2008
    Auckland
    Quote Originally Posted by aussierider View Post
    Yes there will be a drain plug on the side for turbo drain backs.
    Now 9AGTE 410kw atw
    New Zealand
    Quote Originally Posted by Bazda View Post
    Is this going ahead? If so whats the time frame?
    Would be good if the volume was less than 5L's so that a standard 5L pack of oil is good per oil change.
    Logan
    Jul 2008
    Auckland
    Yes it will be around the 5L mark.
    Now 9AGTE 410kw atw
    perth
    how many numbers you got so far ?
    im possibly keen.
    Jul 2008
    Auckland
    Quote Originally Posted by fixeruperer View Post
    im possibly keen.
    Got around 8 guys on the list so far. But will order more to keep in stock.
    Now 9AGTE 410kw atw
    New Zealand
    As mentioned above, since you have nearly got 10 people do you think you will be able to get the price under 500NZD
    Jul 2008
    Auckland
    Quote Originally Posted by SRacin View Post
    Im hoping so, Moroso hasnt come back with their final final price until they finish the design.
    Now 9AGTE 410kw atw
    New Zealand
    Cool. I'm in. Also think there is a bunch of people down here in Christchurch in the car club that would be super keen. It would be good if the flat section allowed the engine to be lowered also.
  1. RWD 3sgte baffled sump
    By af300e in forum Tech and Conversions
    Last Post: 24-07-2008, 10:07 PM
