Results 1 to 7 of 7
Thread: Assembling 4AGZE Piston rings
    Jun 2011
    Default Assembling 4AGZE Piston rings
    Trying to assemble my 4AGZE last night and found out the 2nd ring has a step machined. Is the step should face up or face down?
    Nov 2012
    Sabah
    Default Re: Assembling 4AGZE Piston rings
    Most piston ring have some kind of marking on the ring end. This is also an indication of which side is facing up. I think toyota also have the same method of marking. So the mark should indicate face up. Hope this helps. Cheers.
    Jun 2011
    There are only 2 word and number on the rings 1R, 2R and obviously the size +0.50.
    The machined step has removed some of the ring coatings, will this be an issue?
    Nov 2012
    Sabah
    It should be no issue. unless it is worn out badly.
    Regarding the ring marking, the R1 indicate Ring 1 , R2- Ring 2 and should indicate face-up direction the 3rd ring should have some mark too not neccessaryly R3. Most oil ring have mark some do not.
    Most engine re-build include replacing piston ring. Maybe yours is still in good condition i presume. Anyway hope this helps. Cheers.
    Jun 2011
    These are brand new genuine Toyota rings. Now old reused.
    Jun 2011
    *not old reused
    Nov 2012
    Sabah
    Sorry for any miss understanding. Im not implying that you used old parts bro. If its new then its the best. Anyway hope succsess for your build.
    Just for tip about piston ring arrangement, if im not mistaken, 4Agze has 4 sets of rings, so the ring end should be positioned 45 degree away from each other. Cheers.
  1. 4AGZE piston rings?
    By PrettyCoolWagon in forum Tech and Conversions
    Last Post: 02-04-2011, 04:10 AM
  2. 4AGZE bigport and smallport piston rings - are they the same??
    By cam_ra40 in forum Tech and Conversions
    Last Post: 22-02-2011, 07:20 PM
  3. 1G-GTE piston rings
    Last Post: 12-10-2007, 09:56 AM
