Results 1 to 3 of 3
Thread: Attention steering gurus! Celica ra60 steering wandering/ bump steer issues
    Feb 2011
    Default Attention steering gurus! Celica ra60 steering wandering/ bump steer issues
    hello i have an ra60 which i thought handled okay until i drove it in the wet the other day and it was a nightmare! going over bumps or changes in surface the car would pull either way.
    tyres are good with plenty of tread. front balanced last week. new tie rods both sides. i have been playing with the caster and toe in/ out and was wondering if anyone has corrected this on a ra60 or celica before. whether giving it a bit of toe in or adding more castor as the stock caster rods have lots of adjustment.
    i know changig toe/castor effects bump steer just looking to be pointed in the right direction.
    i know i can just get it wheel aligned but i can afford it atm plus i like to learn things myself.
    patrick
    Stirring an arse clown who cant follow road rules by subtley conforming them, puts a smile on all my dials
    Apr 2007
    Default Re: Attention steering gurus! Celica ra60 steering wandering/ bump steer issues
    If it only drove badly in the wet, i would think the tyres are a big contributing factor, even though they have tread, some tyres are just shit in the wet ..
    Also unless you have some way of checking your wheel alignment its worth spending the $40 or so to get a front wheel alignment done, will save tyres in the long run & maybe steer better too ..
    Victoria, Mt Macedon
    Sounds like you might be majorly toed out. But I also concur with the above. You can do all sorts of ghetto alignment tricks and get things good-ish, but why not fork out $40 and get things set exactly as you want.
    I'd also jack up the front end and check for looseness in everything. See if you can find any knocks/play in all steering and suspension bits. Tighten/replace as necessary.
  1. Attention 18r-g gurus!
    By iTz InSaNiTy in forum Tech and Conversions
    Last Post: 07-04-2012, 02:19 PM
  2. Replies: 8
    Last Post: 17-03-2009, 02:30 PM
  3. Is this Bump Steer??
    By Tom86 in forum Tech and Conversions
    Last Post: 26-05-2008, 03:36 PM
  4. Bump Steer!
    Last Post: 19-07-2006, 07:16 PM
