Results 1 to 15 of 16
Thread: 18rg into rt40
    Default 18rg into rt40
    First question. Can I use the stock 4speed column shift box? Do the 2r and 18r have the same bell housing/gearbox bolt pattern? If I do need to go the floor shift gearbox route what is the easiest way to measure where the hole needs to be? Is the rt40 master cyl big enough to push a w50 slave cylinder? Has anyone got the 18rg to fit with extrctors?
    Top End
    Default Re: 18rg into rt40
    Can I use the stock 4speed column shift box? Do the 2r and 18r have the same bell housing/gearbox bolt pattern? = NO
    If I do need to go the floor shift gearbox route what is the easiest way to measure where the hole needs to be? = Measure or Guess
    Is the rt40 master cyl big enough to push a w50 slave cylinder? = YES
    Has anyone got the 18rg to fit with extrctors? = Not with of the shelf Celica/hilux Extractors they hit the firewall before even fitting never tried Later GT corona ones They may always had to modify or get custom
    Once apon-a-time world famous Photochopper
    http://zammothechoppa.deviantart.com/ : )
    Ok I need help with a shopping list. - engine mounts? Gearbox crossmember? Brake upgrade? Any problems with running a 2 1/4" exhaust? And a randon question, What's the maximum tow capacity of a stock rt40 tow bar?
    Top End
    eng mounts http://www.ebay.com/itm/L-R-Engine-M...3f145d&vxp=mtr
    if you need a gearbox cross member check ebay and gumtree and wreckers
    2.1/4 inch exh. is to big for a 2r and it will sound like ass IMO
    ive had two ronas with towbars one was 500kg the other 800kg either way i was more concerned about the mounting points than i was the bar
    RT81 disc brake front is bolt in jobbie or use early TA22 as done here http://www.toymods.org.au/forums/tec...onto-rt40.html
    I meant to put the 18rg in. I've read something about hilux mounts but nothing about the gearbox mounts.
    Top End
    Ooooooh my bad i hadnt had my coffee this morning
    on the hilux R motors there is engine mount block bracket the left one i think is shorter than the right one you need two of those use the celica mounts as they are flatter than the RT ones
    make a 5-7mm steel plate with 4 threaded hole in it 2 to line up with the xmember brackets bolt holes put bolts in from the bottom grind off excess two from the top through the engine mount holes also ground flush two of these must be done prior to fitting
    Gbox Xmember just needs too sit a few inchs back so any angle or c section thats reasonably thick will do use a modified celica xmember just weld the extra bits to each end too reach the mounting holes un der the RT
    Top End
    and 2.1/4 is nice for RG zorst
    Ok now for some research questions, is it possible to convert an a40 auto to column shift? Is there any toyota auto gearboxes that will bolt to the 18rg that are column shift or can be converted.? Is it possible to manualize the auto?
    Top End
    is it possible to convert an a40 auto to column shift. its possible to convert just about any auto to a column shift
    Is there any toyota auto gearboxes that will bolt to the 18rg that are column shift or can be converted. i believe there are some 18R powered auto vans dunno if they ever sold in aus but
    Is it possible to manualize the auto. in theory yes
    All the Qs you asked are a money + time x work issue
    it would be easier cheaper to go manual
    It only easier to go manual if I can find a pedal box. I can't really justify pulling parts off the 66 because then no one will want it.
    Although I don't think anyone is interested in buying it anyway so maybe I should just scrap it.
    Top End
    well i can let you in on a little secret
    you would prob make more parting it out it will just take a while to sell it
    Ok I've made a wrecking thread now, I've always been curious though. Is there a 6 speed that will bolt behind an r series engine.
    Top End
    first dont limit your wrecking thread to toymods
    put some on gumtree and the network54 corona forum even ebay RT40 parts sell rather quick
    there is no direct bolton 6speed solution but i think its possible to make a Beams 6speed fit and i spose you could also get V16x to bolt to it with alot of work but those boxes are huge comapered to how much room there is in the RTs trans tunnel
    Ok il just stick with my little w50
    Dec 2009
    ca
    Hello there. From the USA here...
    I have an 18RG in a RT52 and being LHD is a little different but installation of the headers are still somewhat the same...
    I modified a TRUST header to fit and it worked out well.
    Installing the 18RG will need new mounts made as the 3R mounts dont work.
    You also need to add tranny mounts to the body side.
    Also a big ass hammer...
    Enjoy and be safe!
