Results 1 to 2 of 2
Thread: R150 input shaft pilot bearing
    Jul 2012
    Nsw
    Default R150 input shaft pilot bearing
    Hi guys
    I'm rebuilding my r150 transmission and I can't find
    The size the pilot bearing race on the input shaft should be in the fsm
    the bearing inner measures 11.99mm and the race on the input shaft is 11.85mm is this
    Acceptable clearance there are some wear marks on input shaft and bearing I'll
    Put up a picture soon as I can any info cheers
    Nov 2011
    Default Re: R150 input shaft pilot bearing
    You should be fine. I think that the bearing is a 6002 but you will get a rattle at idle in neutral once everything is all in and together due to the new clutch disc sitting in a slightly different position to the original. More annoying than problem causing esp with a 1UZ conversion. One trick that we used to use on Skyline and also the UZ swaps in NZ was to use a sintered bronze bush in place of the spigot or pilot bearing, sometimes you had to press two different sized bushes together to get the correct size but while not an issue over there in WA it seems to hard for the average parts "Bone head" to get their head around
    His. 2005 GRJ120 Prado VX
  1. R150 input shaft pilot bearing
    By Spyder in forum Engine & Driveline Conversions
    Last Post: 04-10-2012, 09:04 AM
  2. jz Bellhousing/input shaft measurement
    By Disturbed1 in forum Tech and Conversions
    Last Post: 21-10-2011, 01:11 AM
  3. R154 Input Shaft Length
    Last Post: 29-02-2008, 07:46 PM
