Hi all I am trying to put together a strong long lasting clutch and fly wheel
For rock crawling I have the r150 trans with Dellows custom bellhousing
so far my thoughts are getting a steel billet 5vze flywheel 38lb and having the bolt holes slightly
Drilled with a cnc and fitting a 6 puck ceramic clutch plate with a marlin crawler 10"1600lb press plate
I'm aware the ring gear may also have to be slightly moved also
So is this the biggest strongest setup with heavy flywheel with for the 1uz What setups are others using Any info appreciated cheers
