Have you got the linkage from the carbie to the gearbox attached?
At the back of the carbie, in the 4AC, there should be a small lever that has a hole in it to let the cable (going to the gearbox) to attach. When you depress the accelerator the lever moves, pulling on the cable, which enables the gearbox to downshift and upshift properly.
If the cable isn't attached the gearbox will go from 1st to third and have no kickdown. As you have found out, you can manually select the gears using the stick-shift.
seeyuzz
river
