Results 1 to 12 of 12
Thread: W58 Hydraulic Throwout bearing
    Apr 2011
    Default W58 Hydraulic Throwout bearing
    I'm looking for some advice on what types of hydraulic clutch throwout bearings will fit a W58 5 speed gearbox adapted to a 1UZFE. I have a part number for the howe bearing but am wondering what other bearings can be used. I've heard that quartermaster also make a part but can't seem to find a part number. Also a place where they can be purchased here in Aus. Thanks
    Default Re: W58 Hydraulic Throwout bearing
    JustCallMeOrlando would be one person to speak to? his UZA80 uses a T56 gearbox but he went the hydraulic throwout bearing.
    Otherwise, try Ed's V-8 site: http://www.v-eight.com/
    Ed should have drawing that you can buy off him...
    Uses a Tilton1600 I believe...
    Or shouldn't be too hard to sort out similar yourself
    I have a feeling there is also a cheaper hydraulic throwout that others have used, JCMO springs to mind as someone who has used it
    Wilbo's JZA80
    Wilbo's JZZ12
    Junior Member Backyard Mechanic manny's Avatar
    Here is the Howe 82870 we ran with a SKF VKC3511 \ NTN SFO914 \ NSK GSB319 type round face bearing between our W58 and 1UZ
    GSE20 IS250 - daily
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    The guys from The Cartune Company in NZ use one from a Ford Mondeo.
    Im yet to look into it, as I need one myself.
    Herus
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
    Melbourne Victoria
    the howe 1 seems to be 1 of the better 1s out there and are cheap on ebay
    Quote Originally Posted by Celica RA45 View Post
    Yep I'm pretty sure that was the 'cheaper' one I was thinking of!
    Wilbo's JZA80
    Wilbo's JZZ12
    Feb 2007
    Yup, I've had a Howe (from summit) for 20,000 km or so. Beware that you will need to get a larger master cylinder (5/8 is not enough!).
    Also, don't buy the Howe line kit! It's shit.
    Be aware that by the time you get the bearing, lines, larger master etc, it will cost you as much as a conversion bellhousing, and takes some work to get right. If I had my time again, I'd buy a bellhousing and be done with it.
    Feb 2007
    What Bellhousing would you go for mullett?
    Low rep Grease Monkey
    Apr 2010
    bkk
    intersting information
    SPANNER CRAB Grease Monkey AE3SGTE's Avatar
    Jul 2007
    I'm using a different Howe unit, although has the same part number 82870?
    Its says is designed to be used with 3/4" master cylinder.
    Looks like I have the exact same adapter as manny!
  1. W58 Throwout bearing
    By Teckool in forum Tech and Conversions
    Last Post: 03-12-2008, 03:06 PM
  2. 1jz/w58 throwout bearing
    By Rorge in forum Tech and Conversions
    Last Post: 07-12-2006, 02:03 PM
