its easyer to convert a 1jz with a halfcut but if you have the money go a 2j? dont waste your time with a w series box just get a r154. toyotacressida.net will have all the info you will ever need
Sup.
Me and a mate are putting funds together to build a JZ powered cressy, and we are wondering which JZ is better and what tranny to use (R154 or W58)
Any help would be great!
Callum
10.0sec Cressida (SOLD) current build- caged ke38, 2jz, Glide, 42gtx, 9"
so if i go 2jz its the same as putting a 1jz in but the only difference is $$$
i have a 2jz in my cressida and my brother has a 1jz-vvti in his cressida (both auto)
2jz may be slightly higher power but the 1jzvvti is vastly superior in terms of response and streetability from my experience
MX83 2JZ-GTE!!
#YOLO.
Or buy a older twin turbo 1jz and with money saved single turbo it
[Gentlemen's Club]
Dude, 1Js sound better, and JZX90 will bolt into s2 mx83 or so i am lead to believe. Then go single for dose and all round radness
RT-142 daily drifter, now JZT-142 , projects: hk prem, 40series cruiser, MX-22
Go the 2j for more power
from my experience 2jzgte vvti is much heavier than 1jzgte vvti. Also, all the JZ series TC'ed engines will have pre-OBD2 diagnostics except 2jzgte vvti. Which would also in some cases need fixing immobiliser.
Later 1jz-gte vvti (jzx110,jzs171) and all 2jzgte vvti are more prone to errors in MAF reading unless you run stock airbox
If your not chasing big power, VVTi 1JZ;
Nice to drive, goes pretty hard stock, new-ish motor, cheap
If your looking to make big numbers, single turbo 1JZ/2JZ depending on cash.
Mate I've had both 1J is awesome for tearing up the place ( mine had 4.56 gears in her) but 2j packs a heavy hit mate even with the 3.9's makes my old car feel gutless
