Results 1 to 15 of 20
Thread: 18rc distributor condenser replacement query
    Junior Member Grease Monkey MorgzMods's Avatar
    Aug 2011
    Default 18rc distributor condenser replacement query
    hey all,
    I've replaced the cap, points, rotor button on my 18rc and then the guy helping me realised 18rc's do indeed have a condenser.
    He thought (and i was under the impression) it's an easy swap out with a new one. Which it was up until i checked out the old one after i'd taken it out and compared it to the new one after fitting it.
    two pics to convey basic differences:
    And with the new one installed it won't start. Trys, no weird noises but just doesn't quite kick over.
    The maintenance manual i have displays a connection from the point at which the wire is crimped onto a metal connector that screws into the dizzy, but only in a kind of vague wiring diagram. Not an actual photo.
    The old one did have a connector attached.
    So all in all, it's clear this missing wire is the issue, but how can i solve the problem of the condenser not having one?
    Feb 2012
    Australia
    Default Re: 18rc distributor condenser replacement query
    Why not just solder the new condenser on the old wiring? O___o
    My Daily: NooB's Delivery Vehicle
    My wife's Daily: Series B RA40 Liftback 22RE, power steering, AC. Cushy as.
    Current Project: NooB 3TGTE swap
    Back Burner: 1964 Toyopet ToyoAce, and a Series B TA45 GT coupe
    Too many cars
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    Going to recommend converting to new ignition system, ie elec pickup and control module...
    Feb 2012
    Australia
    Need to find a 21R dizzy, Igniter and coil for that. They arn't easy to find...
    Too many cars
    Jun 2006
    You need to go through the history of the Kettering System and go from there,
    it's pickup signal, adjustable dwell circuitry and coil ohm charge time that's relevant.
    Jun 2006
    Then theres ignition advance = rpm/mechanical and vac advance.
    Aug 2011
    MarcusEstevez
    I trust my crimping skills more than my soldering skills at the moment. I took the easy way out and recreated what i figured toyota already had - a wire running from the condenser to the ignition coil bolt that didn't have a wire running to it from the ballast resistor.
    styler-
    So after a little bit of reading, would it be as simple as grabbing all dizzy, ballast resistor and coil off a 21R/22r engine and swap them out? what more is involved? (i had a read of this but it didn't make much sense to me)
    I am completely new when it comes to this kinda stuff, but happy to learn.
    On a separate note, if i pump the brake pedal in neutral a few times the revs drop significantly to the point of nearly stalling. I'm aware the brakes make use of the engine vacuum (not sure if the right term) but is this normal?
    Feb 2012
    Australia
    Soldering isn't hard dude =P But crimping is alot more practical... no need to plug the iron in, wait for it to heat up etc etc...
    I'm actually going to a wrecking yard tomorrow on the hunt for one of those dizzy's. If theres more, want me to grab one for ya? Apparently it's an easy conversion, everything bolts straight it? I'll try it out if I'm successful on my hunt tomorrow ;P
    Also, no Idea what to do with the braking? Thats very odd... Wheres your Vacuum sourced from? Is it hooked up to the manifold like so:
    Thats how mines hooked up, is your's different?
    Too many cars
    Aug 2011
    Yeah definitely, if there's two i'd love one!
    Damn you and your aircon btw
    I'll check that out today, mine looks a little different due to stock carbie. But i'll have a peek after work
    Cheers!
    Man, if you're replaced your cap, points and rotor button also, then why are we all concerned about the condenser?
    Basics first
    - leads on the right way?
    - points gap set (did you grease them also?)
    if so,
    -are you getting pulse trigger to the coil?
    if not,
    -check you didn't leave the bloody insulating washer(s) off when you installed the new points and condenser, or they're not cracked and constantly grounding the coil.
    After you've got it running, set the dwell and timing and enjoy. You don't NEED to convert to an electronic system, however realize that a points system does require regular adjustments and maintenance.
    Also, pictures of how you 'modified' the condenser to fit the old wiring would be beneficial.
    Feb 2012
    Australia
    Yours doesnt have aircon? I've got a whole system if you want it? Bahah!
    As much as Electronic dizzy's arn't necessarily needed, It can get annoying maintaining a points type dizzy =P
    Too many cars
    A - check that you have spark to start with.
    B - if you have spark did you take the dizzy out when you did this? If so did it go back in the same place ie timing might be out
    C - If you have spark then also check firing order
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Aug 2011
    Cheers for the replies
    The cap, points and rotor button were replaced with the help of a guy that definitely knows what he's doing.
    The cause for replaced the condenser was simply so everything was new.
    Green line is what toyota created with the clip (as well as the blue)
    Blue line is all that the new condenser consisted off
    What i made was the yellow. Simply an insulated copper wire with ringlets? Bolted much the same as the originals were.
    Will this bypass the condenser? By the look of the stock one it was necessary for current from the coil to run through the condenser. (i have no idea if this is how it works though)
    firstly can you do me a favour and try humouring me by putting the old condenser back on exactly how it was BEFORE you did any of this and see if it starts? That will help rule out if it is the new condenser or not. It wouldn't be the first time that i'd seen someone replace something that wasn't broken with a brand new broken one. Obviously if it doesn't start you're probably going to have to start chasing other things - Points/timing etc.
    Further more to that, you don't really need a condenser. IT helps to prevent voltage spikes which can primarily be heard through the radio (stupid buzzing noise or even clicking) You can get away with just the wire from the coil to the dizzy.
    Lemme know
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Aug 2011
    Ah sorry bEn, since putting the yellow wire in place it works
  1. MA61 air con condenser replacement options
    By mullett in forum Tech and Conversions
    Last Post: 11-12-2010, 08:57 AM
  2. lx90 cresta air con condenser
    By surfingisfun in forum Tech and Conversions
    Last Post: 29-05-2010, 12:54 AM
  3. installing 4azge distributor replacement
    By deekay in forum Tech and Conversions
    Last Post: 11-02-2007, 09:23 PM
  4. Electronic distributor 18rc
    By dundee230966 in forum Tech and Conversions
    Last Post: 30-12-2006, 03:02 PM
