This was a thread posted (by me ) on another forum. Given the effort to write I thought it might be worthwhile.
Couple of comments on the article.
There is *NO* way that tiny earth braid is the only thing grounding the engine to the body of that Cuore. Perhaps that's the only earth they could find!
The cross sectional area of that braid is small, maybe 20-30A capacity - no way that will handle the starter.
There must be an additional earth conductor for the starter motor current, hidden from view.
To even imply that the role of engine mounts could be to ground the engine is ludicrous.
Electrolysis?!? Where is the current path that the earthing kits stop? (radiators are rubber mounted for this reason).
Earth points - toyota earth points primarily connect on the thread, and not on the face (which is always painted on the body). If you look at an earthing bolt for a toyota you will notice a good proportion of the thread is "squashed" to enlarge it so it engages the thread in the body with a lot of pressure, giving a good current path - some people interpret such bolts as damaged and discard them.
"Battery negative is best earthing terminal"... When the engine is not running, yes, when the engine is running the alternator ground is more important - the alt supplies the power to everything (including the battery) when the engine is running - so your extra cables maybe should run to BOTH the battery and alternator housing.
"earthing kit may have been responsible for a 1kW gain" 2%... a 1kW difference on a dyno is insignificant..
3-4kw on a circa 300kw engine (on the graph).. 1% also insignificant.. so you'll get an extra 1.5kW The only thing I can think of is better spark - thoughts?
Back to reality..
The IS200 has three ground straps (an RS200 should be no different). One carries the bulk of the starter motor current during cranking, 2nd back of the head, 3rd extension housing of gearbox. However while the engine is running, you have this massive ground connection that is used well below its capacity - the starter isn't running. Starter motors can draw up to 400A at first hit and about 140A (measured on a 4AGE) continuous (in theory a 1kW starter would draw 83Amps).
When the engine is running, the things potentially operating through the starter ground strap (and the other two ground straps, in lesser amounts) are the alternator, the coil pack currents, injector currents, ECU power supply current, all the VSVs, oxygen sensor heaters, auto box solenoids and engine control related currents (except fuel pump) (hope I've remembered them all).
The ingitors/coils and injectors run off a 20A fuse - the maximum current that can flow from this circuit through the ground strap will be 20A.
The EFI fuse is 20A but the bulk of that current capacity is the fuel pump. Even if we overestimate the ECU will draw less than 10A - so 10A running through the ground strap.
The alternator has a certain current capacity (80-120A - don't know the actual rating) which will limit the current running through the earths. This current rating is seldom reached and it certainly wont be needed during maximal engine exertions (things like wipers, windows, seats, etc).
In terms of absolute totals, you have 150A potentially running through the earth straps of the engine - in reality it's a lot less. (In addition keep in mind the engine, when running, is being powered by the alternator, so any grounds on the engine will conduct current directly to the alternator and not through any earth strap to the battery).
The continous current capacity of the three earth straps would be somewhere in the vicinity of the 150A - one 4Gish cable, and two 16G cables. The factory got it right
IF you really *really* want to run an earthing kit running extra grounds to every imaginable part of the engine makes no sense.
1) Run an extra grounding cable from one of the bolts of the starter motor to the battery negative - this gives you a direct current path for the starter motor. Keep in mind a foot of engine block has a much large cross sectional area (hence current capacity) than a foot of 10mm2 cable, so you might not actually improve anything.
2) Extra cable off one of the bolts of the housing of the alternator to the battery (or better still find where the diodes are grounded on the back of the alternator housing and run the cable directly to them - best possible). Makes little sense if the alternator is on the other side of the engine to the battery as the engine block will conduct better than a cable.
3) You could connect an extra 4G grounding cable on the other side of the engine to the chassis (probably won't do much).
None of these are likely to give you any extra power.
When grounding the engine and ECU bits keep in mind that if something doesn't ground on the engine in a certain area, it makes absolutely no sense to give this area an extra ground - you have 100kg of cast iron giving you an almost unimaginable current path - what would you improve by adding a kilo of copper?
Everything on the engine management side on the 1G-FE grounds at two points on the cam cover. You could connect extra cables to those two points to the battery (alternator makes no sense again as the block will conduct better).
Otherwise, you could be more creative and ground the components that use those two ground points and improve on the length wiring that the factory runs in the loom - IE all the ignitors/coils have a ground pin - you could each ignitor directly to the battery and/or alternator.
The ECU has a number of high current ground connection, some of which run the injector currents - you could connect the ECU grounding pins straight to the battery and alternator (but leave the sensor signal ground alone).
You could connect the grounds of the oxygen sensors directly to the battery or engine block.
The only thing that has potential to give you extra power here are the coil packs but afaik the spark delivery is more than adequate in the factory application. That's pretty much the only thing that I can think of that could've made a difference on the skyline - spark quality is more critical in boosted application.
In terms of the injectors doing something differently - you may get slightly crisper opening times... real world value?....
Thoughts anyone? on anything?
Hopefully someone will read it There is *some* grounding advice
Mos.
