Page 9 of 9 FirstFirst ... 789
Results 121 to 129 of 129
Thread: First 3UZ-FE conversion maybe?
  1. #121
    Nov 2011
    Default Re: First 3UZ-FE conversion maybe?
    its easier to send ecu to George and bypass security
    2 less things in the system
    only reason to go with immob ecu and key is if u want some sort of security
    or if u have a complete set
    an immob ecu is easily over 200 or 300 bucks
    a key reader is around 150 bucks
    then u need to find the correct keys
    once u have a new or virgin ecu or immob ecu
    the first key it reads when ign is turned on is the master
    then u can use techstream to read the next 2 I think
    I know on fords u need 2 keys programmed before u can exit the key programming sequence
    I have the Toyota immobiliser/security cd so ill have to load it up and se what it says
    but it wont have the 3uz in there so ill have to find something similar
  2. #122
    May 2010
    Moscow
    Another 3uz conversion! With true duals exhaust this time
  3. #123
    Jesus. That engine in that shitbox - sleeper to the max!
    Even just on trailing throttle past the camera, so many loves xx
    ps: needs moar LSD
  4. #124
    May 2010
    Moscow
    Quote Originally Posted by Draven View Post
    ps: needs moar LSD
    If it was my car, it would have one ))
  5. #125
    Hey George, have you any idea what the pressure might be on the power steer pump 3UZ LS430 (2002)
    I am using the Lexus pump to power the Porsche 928 rack. the nominal output on a Porsche PS pump is 70 bar( later models were stamped 100bar- SHEEEEIIIIT!-is there a decimal point in there that I've missed?)
    The Lexus had electric boosted rack, so I suspect the PS pump had not that big an output.
    The combination Lexus pump, Porsche rack is a bit too heavy at speed, and power assist non existant at low speed- and real bad heavy when parking.
    Is there any way to increase the Lexus pump pressure ?
    Or.... will any of the earlier non electric assist pumps swap in?
    I think (not sure) that I may have got the pressure up a little by removing the "clamp over" restrictor that is on the high pressure hose just below the low speed turn vacuum operated valve. Hose has returned to the original shape, but not really sure if the steering is any lighter.
    Russ
    3UZ Porsche 928S
    30 year old supermodel, great ass, crazy eyes, erratic mood swings and more grunt than a hippo with haemorrhoids
  6. #126
    May 2010
    Moscow
    I assume the pressure is damn high.
    The car in the thread's first post runs steering box, and so does mine (with 1uz vvt). No issues at all. A steering box usually needs way more pressure than needed by a rack.
    LS430 didn't have electric boosted rack, but it might have had progressive power steering with electronically modulated pressure control valve. That valve however can only reduce the pressure. All of the pressure is still developed in the belt driven pump.
  7. #127
    Jul 2009
    va
    Good info here. I've had a 1uz vvti with needed key, transponder, etc for several months that I planned to swap into my MX83. However, I just pulled a 3uz from a wrecked 2001 LS430 this past weekend. I know it's a more complicated swap with the seperate immobiliser ecu and drive by wire. I have noticed that the sensors on the 1uz and 3uz are identicle and in the same locations. This leads my to think that the 1uz harness/ ecu and throttle body can be used to run the 3uz. I know the displacement is different but shouldn't the ecu be able to cope with this relatively small difference?
  8. #128
    May 2010
    Moscow
    One guy at Lextreme told me this is possible, but I haven't personally tried running a 3UZ with 1UZ loom. Depending on the exact cars you took your 1UZ ECU/LOOM and 3UZ ENGINE off, you may need to replace some things on your 3UZ. Like AFM, coil packs, throttle body.
    Also, keep in mind that I offer bypassing immo in any 3UZ-FE if customer sends me his computer, and I even got a number of ready to go ECUs.
  9. #129
    Quote Originally Posted by George View Post
    Thanks, I'm left handed, most left handed people think things through logically, then come to conclusions that are the exact opposite of what things should be. I had figured it was a low pressure pump with electric assist, nope, high pressure pump with electric reducer.
    It took a couple of days , but the removal of the clamp/reducer on the high pressure hose seems to have lightened the steering a bit, probably needed time and pressure to open the 12 year old line to it's original size (think I worked that one out right.)
    Russ
    3UZ Porsche 928S
  1. Replies: 4
    Last Post: 27-11-2011, 10:43 PM
  2. 22R LPG Conversion
    By rex_hvn in forum Tech and Conversions
    Last Post: 31-08-2009, 06:23 PM
  3. 2.4lt conversion
    By mycarona in forum Tech and Conversions
    Last Post: 11-03-2009, 11:27 AM
  4. 2S -> 3S Conversion
    By 81rolla in forum Tech and Conversions
    Last Post: 22-02-2006, 02:08 PM
