Sump? RA65 fuel system? Engine mounts?
It's really one of those "how long is a piece of string questions" dude, it will depend on how much you can get everything for, and how much of the custom stuff you can do yourself.
hey all,
i have an ra60.
if i had a 3sge, rwd exhaust manifold, quad throttle bodies, a s series egine to w series gearbox bellhousing, a sa63 crossmember and a microtech. what else would i need?
if i did all the work was done by myself and a mate how much would this conversion cost?
thanks, any information would be useful.
Have a search.
RWD'ing any of the 3S's is a very expensive thing to do.
Almost nothing is available off the shelf, and thus needs to be custom.
Its up there as one of the most involved conversions available.
A 3S-GE conversion might be slightly easier than a 3S-GTE conversion, but yeah it's still a big job. It also might help a bit if you started with an SA63 instead of an RA60. They cost stuff-all these days so you might as well.
One big thing you missed is the distributor, which sticks out the back of the head on a 3S. This is a bit of a problem when you try to mount the engine north-south.
Norbie!
www.norbie.net
Yeah, I'd be using the microtech, getting a crank-angle sensor made up, running coilpacks, custom intake (as you mentioned), RWD headers, Altezza 6speed box...etc
I think the BEST way to do it (might not be the cheapest, but but then again it might be) is to get an SA63, an Altezza front cut, and uhh...pursuade...them to join together. THis way you've got all the RWD stuff, the ECU will happily run it, a heap of factory-reliable power...etc.
RM.
and don't most 3sge's have vvti? which you would need an expensive ECU to run.
edit: that's just the rs200 ones aint it, my bad. end edit:
good luck if you go through with it.
beer me!
Im about to face the daunting task of 3SGTE into RA23... and Im estimating 7G to do it, with a W58, as the Altezza box seems impossible to get (if anyone has one for sale, let me know) and thats with good friends of mine doing all the custom fabrication for booz/cash
Its not a cheap convo, and should not be attempted as one. If you want a cheap convo... 1GGE seems the go with W57 box etc etc.
if there was no such thing as engineers certificates i would of poped the 3s in my car in stead of hybred shannigans
in all seriousness it's not really that hard when it comes to engine convos if the ra60 shares the same xmemeber as the sa63 it's a walk in the park really 2s engine mounts bolt up pretty much just gotta weld a bit of 1/4 inch on one mount and drill a hole run a 2s sump and pick up run a sa63 gearbox and machine the bellhousing down and bash the firewall a bit or run coil packs and shes in then you just gotta fiddle around with little stuff
in engine convos terms it's in the simpler side of the equation i've seen 351's in mk1 cortinas now theres a bugger of a conversion choping and welding of firewalls and trans tunnels or let alone vn v6's in gemies
Yeah, gotta love the Gingerbeering side of things. Ive had suggested to me to rig up the OEM dizzy on the front side of the motor on one of the cams... dunno how that would work... may look into it. Otherwise its gonna be a programmable ignition system with quad coils for this black duck
hmmm how in the good name of toyota would you rig the dizzy up like that
i've seen people run dizzys off the cam belt with a gear/cog off the end of the dizzy but you would need to fab and find out ratio the gear/cog would need to be to spin the dizzy at the right speed per revolution
call me dogey if you want but i still find the sleg hammer/belting of the firewall idea much easyer and cheaper although if i was building a half decent car and i did'nt have 20 million projects at once i would be looking at running coils just much neater
yeah, coils was my preferred option too... and i dont like the thought of taking to my soon to be show quality RA23's firewall with a sledgy.... just not my style.
wow, this is the most impressive attempt ive seen to make an engine conversion like this seem easy, to date.Originally Posted by sam-131
i dont care, this deserves rep!
Eldar.O.
crank trigger and coil packs for waste spark - that'll make the dizzi a non-issue... but it's a minor issue compared to mounts and (if you go turbo) starter motors.
so nobody has mentioned the apparent oil drainage issues that result from the head being upright?
Im going to look into having the motor on a tilt, see what fitment issues that causes. The ol RB series of nissan 6's are slanties... so why wouldnt a 3S work as a slanty i say... just means a slightly tighter bend on the dump pipe, and possibly some custom bonnet alterations. Good point you make tho Viper.
Chuckster... wasted spark is for commonwhores and foulcans. quad coil packs running in correct firing order are for real motors. Works in the same way as a V8 wasted spark, just need to make a correct crank trigger disk. As the dizzy comes off a cam with no gearing, this can be done quite easily with a 3S
